Engine weird sound - 3.2 - XC90 2011
CleVolvo1
Year and Model: 2011 XC90
Post by CleVolvo1 »
Hello all,
I have a 2011 XC90 with 150,000 miles, AWD, and has the 3.2 in it. When I am driving and depress the gas pedal, basically putting some pressure or torque on the car, the engine sounds like it is pinging, scratchy, marbles, or rough, the engine runs smooth at the same time. This is very obvious when I am going up hill. I will have the pedal down a little bit and the sound is smooth, but when I press the pedal a little more the sound I am referring to comes in. I run 93 octane and the car has new plugs, air filter, and oil change.
Quick notes:
The previous owner probably ran cheap gas, I am have been putting in 93 octane -
The engine seems to be a smooth runner other than the weird sound when torque/power is applied.
I picked up the car with about 146,000 on it.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Can you shoot a video of it? It'll give us a better chance at diagnosis. Windows up, radio off for best results.
Also -> Amazon link
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
Start with new spark plugs
I recommend
Denso (5344) IKH20
This is what I run in both of my 3.2’s
For more information see this thread
viewtopic.php?f=10&t=88362
After spark plugs the PCV would be a good place to check next
Post here your results (even if you find out a different root cause)
Good luck
Paul
pgill
Post by pgill »
A picture of the spark plugs for my S80 at about 123,000 miles
I replaced these right away when I bought my S80 (used)
CleVolvo1
Post by CleVolvo1 »
matthew1 wrote: 10 Apr 2019, 10:21 Can you shoot a video of it? It'll give us a better chance at diagnosis. Windows up, radio off for best results.
I have video however the two clips are 70MB and 26MB I am not sure if this site will allow large files as such.
CleVolvo1
Post by CleVolvo1 »
pgill wrote: 14 Apr 2019, 17:19 A picture of the spark plugs for my S80 at about 123,000 miles
I replaced the plugs already, they were all pretty much done, and I mean DONE!
pgill
Post by pgill »
What Spark plugs did you buy?
CleVolvo1
Post by CleVolvo1 »
NGK
CleVolvo1
Post by CleVolvo1 »
Quick note I do have another XC90, exact everything, that seems to be coming into this same problem. It has OEM dealer plugs.
matthew1
Site Admin
Post by matthew1 »
CleVolvo1 wrote: 17 Apr 2019, 12:52
I upped the attachment max filesize allowed. Please try now.
Also -> Amazon link
