Hello all,
I have a 2011 XC90 with 150,000 miles, AWD, and has the 3.2 in it. When I am driving and depress the gas pedal, basically putting some pressure or torque on the car, the engine sounds like it is pinging, scratchy, marbles, or rough, the engine runs smooth at the same time. This is very obvious when I am going up hill. I will have the pedal down a little bit and the sound is smooth, but when I press the pedal a little more the sound I am referring to comes in. I run 93 octane and the car has new plugs, air filter, and oil change.
Quick notes:
The previous owner probably ran cheap gas, I am have been putting in 93 octane -
The engine seems to be a smooth runner other than the weird sound when torque/power is applied.
I picked up the car with about 146,000 on it.
Engine weird sound - 3.2 - XC90 2011
- Has thanked: 714 times
- Been thanked: 312 times
Re: Engine weird sound - 3.2 - XC90 2011
Can you shoot a video of it? It'll give us a better chance at diagnosis. Windows up, radio off for best results.
Also -> Amazon link. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 29 times
- Been thanked: 46 times
Start with new spark plugs
I recommend
Denso (5344) IKH20
This is what I run in both of my 3.2’s
For more information see this thread
viewtopic.php?f=10&t=88362
After spark plugs the PCV would be a good place to check next
Post here your results (even if you find out a different root cause)
Good luck
Paul
I recommend
Denso (5344) IKH20
Good luck
Paul
- pgill
A picture of the spark plugs for my S80 at about 123,000 miles
I replaced these right away when I bought my S80 (used)
I have video however the two clips are 70MB and 26MB I am not sure if this site will allow large files as such.
I replaced the plugs already, they were all pretty much done, and I mean DONE!
Quick note I do have another XC90, exact everything, that seems to be coming into this same problem. It has OEM dealer plugs.
I upped the attachment max filesize allowed. Please try now.
