Definitely correct. All 97-98 LPT are 4.4. That's why you want to get a matched 4.4 if you drop in an HPT ECU.Gmstewart22 wrote: 15 Apr 2019, 00:57 I'm pretty sure I have the Bosch motronic 4.4 engine management system already in that car. I looked up the info off the cars vin number.
13t boost questions
- Has thanked: 312 times
- Been thanked: 818 times
- Gmstewart22
- Year and Model: 2000 v70 GLT, 850-T5
- Has thanked: 11 times
So while we are on the topic of turbos.. is it another misconception that by installing a downpipe hou can increase boost pressure? Iv heard that it allows the turbine to spin faster this creating more boost.
2000 v70 GLT
1997 v70 AWD lpt
1997 v70 AWD lpt "rally rig"
1995 850 T5
1997 v70 AWD lpt
1995 850 T5
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
Dang - I thought I was being so diligent.erikv11 wrote: 15 Apr 2019, 14:24 Thanks for fixing that - 13g, not 13t !!
Also you highlighted the wrong line in the bottom graphic () - OP has an XC not a GLT. But same turbo/engine yes!
Why are you bringing up the characters "15t" here ? Not following.
The “15T” has been mentioned a few times in this thread - not by you! - and it doesn’t exist, so I thought I’d mention that as well.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Sommerfeldt
A bigger downpipecan decrease backpressure from the exhaust, and let gases flow more freely. That won’t let you build more pressure - that’s controlled with the TCV and the wastegate, coupled with the size of the turbo, of course - but it will let the turbo spoil quicker. It’s helpful with a bigger, slower turbo, which otherwise would have long lag times.Gmstewart22 wrote: 15 Apr 2019, 15:07 So while we are on the topic of turbos.. is it another misconception that by installing a downpipe hou can increase boost pressure? Iv heard that it allows the turbine to spin faster this creating more boost.
Note that a down pipe, often coupled with a larger intercooler, can necessitate changes in the tune due to the airflow and characteristics of the spool-up, since it will also move the boost down through the rpm range.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Gmstewart22
I see thanks for the information. I really like the quick spool of the 13 on the lpt cars but they just lack a little on the top end. If I could only get a 16T to spool like a 13T or 13G. The only option is to do a sequential setup small turbo for the bottom end big turbo for the top
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
1997 v70 AWD lpt
1995 850 T5
- Gmstewart22
To answer the above I do have a GLT as well but the car in question is as erikv11 wrote a v70 xc is the car in question..
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
1997 v70 AWD lpt
1995 850 T5
Sommerfeldt
There's always a trade-off somewhere, but I'd say a 15G might be the best compromise. It's an HPT, so you can crank it up to about 20 psi if you want, but it's petite enough to spool up pretty fast. With a larger downpipe and good breathing, you shouldn't see any lag worth worrying about with even a 16T.Gmstewart22 wrote: 16 Apr 2019, 20:37 I see thanks for the information. I really like the quick spool of the 13 on the lpt cars but they just lack a little on the top end. If I could only get a 16T to spool like a 13T or 13G. The only option is to do a sequential setup small turbo for the bottom end big turbo for the top![]()
I don't have a problem with lag in my car at least, on the 15G.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- Has thanked: 1611 times
- Been thanked: 4075 times
I love the lag on my HPT
It gives BMWs that fleetingly second of hope, only to be dashed shortly thereafter by the back end of Moms’ station wagon.
- Gmstewart22
In Wyoming where I lived at the time there were long straight stretches with no trees for miles, had that car up just over 150 on my GPS and she was still pulling slightly! Ever since then I've been a VOLVO fan!
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
1997 v70 AWD lpt
1995 850 T5
- Gmstewart22
What am I looking at cost wise for a 15g and a tune? I'm thinking I'll go for it if I can make it happen for around 2k-2.5k
2000 v70 GLT
1997 v70 AWD lpt
1995 850 T5
1997 v70 AWD lpt
1995 850 T5
- 21 Replies
- 5596 Views
Last post by j-dawg
- 11 Replies
- 1893 Views
Last post by erikv11
- 1229 Views
Last post by NSFWaldo
- 1402 Views
- 10 Replies
- 2855 Views
Last post by phils94850
