Did you know? 🤔
2001 - 2007 XC-70
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 29 times
Been thanked: 20 times
United States of America
EngineeringBloke
Re: What did you do to your P2 Volvo today....now sticky!!
Post by EngineeringBloke » Sun Apr 14, 2019 9:46 am
Pull up your dipstick (1 cm?) to releave PCV pressure until you do the PCV job.
These users thanked the author EngineeringBloke for the post:
Antoine240bk
MDK
Year and Model: 1998 xc 70
Has thanked: 0
Been thanked: 27 times
MDK
Post by MDK » Sun Apr 14, 2019 1:12 pm
Changed the oil...211,000. 2002 07 NT
Antoine240bk
Year and Model: XC70 2.5T-2006
Has thanked: 10 times
Been thanked: 13 times
France
Antoine240bk
Post by Antoine240bk » Sun Apr 14, 2019 1:29 pm
abscate wrote:
Sun Apr 14, 2019 5:42 am
There’s an improved one that doesn’t cough out the pin and ruin your engine. I’ll try to find the thread with all the part numbers to confirm.
I will put notes on this thread once i'll start the PCV job. I see that FCP have all the kit needed.
viewtopic.php?f=9&t=85431&start=20
Volvo XC70 2.5 T AWD P2 BVA B5254T2 12/2005 Four-C EX : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -Gpl - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
oragex
Year and Model: S60 2003
Has thanked: 82 times
Been thanked: 189 times
Canada
oragex
Post by oragex » Sun Apr 14, 2019 1:47 pm
Pulled from the junkyard a set of aluminum door trims from a T5, going to install them with my tan interior. Also got a set of rear tweeters from an XC70, these are going into the front doors near the main speakers, at the second grid opening (this grid is used for the premium double speakers). These XC70 rear pillar tweeters (sit right near the trunk lid) are beefy and much larger than even the premium front tweeters.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 384 times
Been thanked: 145 times
matthew1
Post by matthew1 » Mon Apr 15, 2019 12:56 pm
Oragex, I split off your seat video post into P2 seat information, how to ID, what to look for, and comfort opinion.
It's too good not to! Here's the video for those who don't want to follow the link above:
Also -> Amazon link
. Click that when you go to buy something on Amazon and MVS gets a kickback.
1997 850 T5, MSD ignition coil, Hallman manual boost controller, injectors, R bumper, OMP strut brace [gone]
MDK
Has thanked: 0
MDK
Post by MDK » Mon Apr 15, 2019 2:51 pm
Changed the oil..2002 V70. 211,000 NT
ndphotonl
Year and Model: S80 2.4T Wasa
Has thanked: 17 times
Been thanked: 21 times
Netherlands
ndphotonl
Post by ndphotonl » Tue Apr 16, 2019 1:36 pm
Bought and fitted the so called HD TCV, which is basically a Pierburg unit with type nr: 7.22908.03.0 . Its used in Porsches & Rovers. I noticed positive change, especially with partial throttle. Recommended update if you have a tired TCV!
ImageVolvo S80 2.4T Pierburg TCV 7.22908.03.0 by Andy Ramdin, on Flickr
These users thanked the author ndphotonl for the post (total 2):
matthew1bepilot
Volvo S80 2.4T Wasa Limited Edition
Blog / FlickR / YouTube channel
bepilot
Year and Model: 2001 S60 2.4T
Has thanked: 2 times
France
bepilot
Post by bepilot » Wed Apr 17, 2019 2:37 pm
^^ will keep this one in my reminders, dankjewel!
I changed my lava lamp rear view mirror with one of a ‘14 xc90, it was a bit of diy but it works!
2001 S60 2.4T manual
It's not 'tuning' we're after, it's 'continuous improvement'...
oragex
Canada
oragex
Post by oragex » Wed Apr 17, 2019 4:41 pm
Two videos with the fast idle and the sunroof drains cleaning - in particular in the second video I talk how my side airbag got wet because of a clogged sunroof drain
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 4 times
Been thanked: 32 times
E Showell
Post by E Showell » Sat Apr 20, 2019 6:32 am
Ruby Red 2004 XC70 got new front lower control arms (Lemforder), ball joints (Lemforder), front rotors (Zimmerman) and pads (Akebono ceramic). I think the front calipers are tired and need to be changed as well.
Have sway bar end links and outer tie rod ends that need to be done as well, but we ran out of time. The struts and related hardware had been done 10 k miles ago.
As of now, I am pretty far along on the $5,100 worth of work the dealer told the prior owner it needed. (Not surprisingly for far less than $5,100.)
I have the CTA ball joint tool that I am thinking of making an MVS loaner now that mine are done. Air hammer was pretty much a necessity to do the ball joints, but it does ding up the knuckle a bit.
Sway bar end links went on today (Lemforder).
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
