A part inside my CEM is broken (the CSH1 and CSH2 connector , it’s a little black box) and I don’t have any power in my left turn signals
is it possible to get a new “connector” and if so what are they called, and saughter it back to the CEM.
If I were to buy a CEM would I need to program it to my car or would they already be programmed and thus I could just swap out the old one for the new one. Without needing any extra work (programming) to the CEM that I buy
I’m just looking for the cheapest and easiest way to fix
Does it need to be the exact same serial numbers ?
Any help is appreciated Thanks
When does a CEM need programming? 2001 Volvo S60 Topic is solved
Alexis2929
- Year and Model: 2001 S60
- Has thanked: 6 times
- Year and Model: Lots
- Been thanked: 128 times
CEM contains key information and car configuration all which are unique to your car. Basically it won't start if you swap it out.
They can be re-programmed by XeModex but they'll need the original as well as the donor.
- 3394 Views
Last post by precopster
- 27 Replies
- 27938 Views
Last post by cn90
- 5567 Views
Last post by RickHaleParker
- 411 Views
Last post by faircam
- 8944 Views
