IPD sale Volvo Parts
Did you know? 🤔
When does a CEM need programming? 2001 Volvo S60 Topic is solved
2001 - 2007 XC-70
Alexis2929
Year and Model: 2001 S60
Has thanked: 3 times
Been thanked: 0
United States of America
Alexis2929
Post by Alexis2929 » Sat Apr 20, 2019 11:43 pm
A part inside my CEM is broken (the CSH1 and CSH2 connector , it’s a little black box) and I don’t have any power in my left turn signals
is it possible to get a new “connector” and if so what are they called, and saughter it back to the CEM.
If I were to buy a CEM would I need to program it to my car or would they already be programmed and thus I could just swap out the old one for the new one. Without needing any extra work (programming) to the CEM that I buy
I’m just looking for the cheapest and easiest way to fix
Does it need to be the exact same serial numbers ?
Any help is appreciated Thanks
SuperHerman
Has thanked: 0
Been thanked: 97 times
SuperHerman
Re: When does a CEM need programming? 2001 Volvo S60  Topic is solved
Post by SuperHerman » Sun Apr 21, 2019 8:21 pm
A CEM needs programming in two cases: 1) if it has no software loaded (brand new) or 2) if the software loaded is not correct for your vehicle (debate is open on loading different software, but consensus is it can be done).
If you have a working CEM with a bad connector, you can swap the connector from ANY used working unit to your broken unit that has the same connectors you have issues with. This assumes your unit is functioning except for the connectors. A connector stores no software.
So, reading between the lines, you have a CEM where you believe the CSH1 and CSH2 connectors are bad. If you have the solder skills you can move these from a donor unit to your unit. Again, you have the skills and you know these two connectors are the only issue.
If you want to swap CEMs in their entirety, then you need to swap like for like (model year and part number usually works). The downside is the CEM will take the highest mileage portion, either your car or the donor CEM, and display that as the mileage. So best approach is to find a CEM with mileage lower than your car. End result is a showing of your car's actual mileage. This works most of the time, as at the age of these vehicles the dealer has already installed the correct latest software. This is not always the case, some cars slip through the cracks. If you have VIDA you can confirm the software version.
Does this clarify?
These users thanked the author SuperHerman for the post:
Alexis2929
Year and Model: Lots
Has thanked: 4 times
Been thanked: 93 times
Australia
Post by precopster » Tue Apr 23, 2019 6:45 am
The software versions can be identical but key information is stored on the CEM so without some degree of programming they can't be swapped out. Also if the VIN stored on the CEM doesn't match the VIN on the body/windscreen plate Volvo will not work on the car. For some people that's a blessing. Also dealers won't reload a used CEM as it's against policy.
If you're going to buy a used one these early CEMs need to be shorted so a programmer can access the car using a Dice diagnostic tool through your internet connection. I've swapped out about 7 early CEMs with a programmer's help. Doing it this way ensures a successful cloning from old to new.
These users thanked the author precopster for the post:
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
