IPD sale Volvo Parts
Did you know? 🤔
07 S60 Immobilizer / Communication Errors / No Start
2001 - 2007 XC-70
d3ktrix
Year and Model: 2007 S60
Has thanked: 7 times
Been thanked: 0
United States of America
d3ktrix
Re: 07 S60 Immobilizer / Communication Errors / No Start
Post by d3ktrix » Tue Apr 23, 2019 5:56 am
precopster wrote:
Tue Apr 23, 2019 3:31 am
Look up number of keys fitted in CEM parameters. Could be that key data is lost. Are you using Vida?
It shows 2 keys fitted.
We have tried both keys and the car behaves the same with both. The batteries in them are good.
I'm using an Autel Maxisys pro.
Thanks
Year and Model: Lots
Has thanked: 3 times
Been thanked: 93 times
Australia
Post by precopster » Tue Apr 23, 2019 6:21 am
Because most codes are ECM based and there are now ghost codes such as camshaft sensors I'm going for either a faulty ECM or a dirty ECM edge connector. Has this been cleaned yet?
The latch code for the keys is held in the ECM so that makes sense that the immobiliser display is showing as well as relay codes.
Current cars:2002 XC70, 2006 Ssangyong Rodius (Stavic), 2006 XC90 2.5T, VW Transporter 2.5TDI
www.precisioncarmodules.com.
d3ktrix
Been thanked: 0
d3ktrix
Post by d3ktrix » Tue Apr 23, 2019 6:32 am
I have not done anything with the ECM yet. Though I noticed that also.
I'm guessing the edge connector is the main connection on the ECM when it is slotted into the car?
I do not have the special tool to remove the ECM. Though no problem buying it if we need it.
Australia
Post by precopster » Tue Apr 23, 2019 7:24 am
Yes the edge connector is on the base of the ECM. There are pink sliders in there that can release the modules but I'd rather use the special tool.
Wouldn't hurt to clean the TCM with electrical contact cleaner while you're in there.
These users thanked the author precopster for the post:
d3ktrix
d3ktrix
Been thanked: 0
d3ktrix
Post by d3ktrix » Tue Apr 23, 2019 7:33 am
Yeah I just found a YouTube video explaining how the pink sliders work without the special tool. I'll pop the plastic shroud off ECM/TCM and see if I want to mess with the sliders lol
Thanks for the info.
Australia
Post by precopster » Tue Apr 23, 2019 7:54 am
Bosch computer is ECM. The other one is probably marked TEMIC.
d3ktrix
d3ktrix
Been thanked: 0
d3ktrix
Post by d3ktrix » Tue Apr 23, 2019 1:35 pm
Well I think we figured it out.
The connectors on the ECM looked great, but I noticed it looked like water had been flowing down the side of the aluminum ECM cover in the past. So we popped the ECM open and it had corrosion everywhere on the back side of the PCB.
Wonder if ultrasonic cleaning would bring it back to life or if it needs to sent out or if its shot lol
Ill try cleaning it first and go from there I guess, we'll find out if anything burnt out.
Thanks for the help everyone.
And thank you precopster for pointing me towards the ECM =)
RickHaleParker
Been thanked: 303 times
RickHaleParker
Post by RickHaleParker » Tue Apr 23, 2019 2:20 pm
Could be mineral deposits (from the water) creating leakage currents.
Wash the board with Electrical Contact Cleaner.
These users thanked the author RickHaleParker for the post:
d3ktrix
Platform: P80 1998 C70, B5234T3, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0, Plant Torslanda Sweden.
d3ktrix
Been thanked: 0
d3ktrix
Post by d3ktrix » Tue Apr 23, 2019 2:31 pm
You might be right, i was thinking it already went the step further and turned to corrosion.
I will def try to electrical contract cleaner right now before taking extreme cleaning measures haha.
Thanks again.
Australia
Post by precopster » Tue Apr 23, 2019 10:47 pm
A used ECM with the same Bosch part number can be cloned to suit the car. You'll need a Windows laptop and a Dice tool. I can fill you in and point you in the right direction with regard to who can do this for you when/if the time comes.
