1999 S70NA Manual Climate Control MCC 3524842 9171601 Cable attachment
Has thanked: 1504 times
Been thanked: 3817 times
My passenger temp control was not regulating, reaching around the dash, I could feel the cable had popped off the MCC gudgeon, so I went to work
Unlike an ECC controller, the MCC controller is removed by unscrewing the rear part (the part you see) from the console frame, then unclipping the FRONT part (hidden in dash)
From there, you can manipulate it enough to reattach the cables with some tricks
Unclip the cable from the frame (snap in) so that it is free
The eye on the cable goes on the gudgeon, the wire gets retained by the C clip built into the plastic gudgeon
Put the eye on the shaft, then turn the temp knob hot to use the frame to retain it.
Tools
Torx T15 for screws
SPudger to release plastics frame and clips
Put a shot of silicone spray into top of each wire to make things move smoothly
Elapsed time 25 minutes
*** Be careful with that MCC - its a $450 part and eBay is no help - hard to find in PnP.
Update on the MCC controller $320 at FCP for 1998-2000
Volvo Heater Control Unit - Programa 9171601
C70, S70, V70
Part #: PRO-601
Picture Gallery
I put the knob back on to go to COLD position to connect wire, then turn to hot to retain
Working through hole, you can manipulate the controller to get wires connected correctly
Heres why passenger was always at constant Temperature!!
Pass enter side installed correctly
Rear side of MCC controller pulls forward, release with spudger on sides and top/bottom
Unclip two clips on each side of MCC controller, then push it forward
Two plugs connect to REAR of MCC controller
Here is the driver side in correct position
Same on the pass side
Nice and easy on old plastic
Just grab and tug
Just grab and tug
Temperature knobs pop off, note T15 screw
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Nice writeup. Those cables are a pain to work with, and the MCC unit is a lot more complicated to remove than the ECC. I'm currently removing the MCC unit from the 850. Fortunately this one works, so I'll give someone a good deal on it if they need it!
My recent 1998 parts car has MCC, so I now have a spare controller . Im actually not too inclined to sell given how hard these are to find.
Hmmmm, lights are out on the MCC head
Diagram…looks like first check will be in B18 with lights on.
Poof. programa 9171601 now backirdered at FCP
Programa in FL will rebuild for $250-300 with core sent in.
Brought my spare mcc control unit but as I pulled off the knobs and manipulated the plugs the lights flashed.
It turns out pressure on the rear face makes the lights intermittent. We put a spacer between the rear face and the mechanical cable unit and all is wellll
Has thanked: 1846 times
Been thanked: 1710 times
Sounds like some loose solder joints.
Glad you got it working though. No lights on the unit at night is no fun.
Ah, I know what’s going on
The bulbs bayonet the front of the circuit board on the MCC unit. The electrical connection is inside , on the rear of that board.
Slight Pressure on the bulb holders will disconnect the connections in the board and ,,,,, lights out
Picked up Up a cheap one at flea bay. Advertised as a ECC at$35, dropped it in my cart for a week and waited for an offer. $22 shipped. Tested good today
I feel Scottish
