Hello,
What is the procedure to install timng pulley on crankshaf? Lets conisder the shaft was rotated. How to find the coresponding position between the timnig pulley and the crankshaft?
Crankshaft timing pulley position
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Isn't the timing pulley keyed?
- Has thanked: 1613 times
- Been thanked: 4075 times
It is, unless the splines are ruined. (Very rare)
Clean the splines by pulling a rag with carb cleaner through and you will see there is a thick spline that has to match the wide notch.
It will only go on one way.
- 2779 Views
Last post by Williamad33
- 1420 Views
Last post by DGB47
- 824 Views
Last post by DRN2001
- 2588 Views
Last post by oragex
- 453 Views
