2000 V70R Whining/Buzzing Noise in Engine Bay
This topic is in the MVS Volvo Repair Database » CVVT – What They Do & Why
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
scot850 wrote: 16 Apr 2019, 17:20 The ETM initialises when you switch the ignition on. It whines and buzzes but for only a few seconds or so. If it continues to do so it be it is failing.
I'm familiar with that noise, but I don't think that's what it is. It's similar, but the noise goes up and down, unlike the ETM noise. I can still hear the ETM though, so I'm pretty sure it's not the same noise.
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
It sounds like bearing clatter to me. I hear metal rubbing. It sounds very similar to the noises my belt tensioners made before my timing belt water pump debacle. But this is all speculation from your video! I'd pull the t/belt cover and see if it gets louder.
Has thanked: 1611 times
Been thanked: 4072 times
No, its a high pitched, like 1kHz buzz.
Im thinking alternator or possibly CVVT hub wear noise.
bmdubya1198
Yeah, it's definitely not mechanical like a bearing.
I listened to it this morning, thinking it may be the ETM as I listened in that area, but I definitely hear it most around the alternator area. Maybe it's the alternator, who knows. I'll take a closer listen this afternoon. I wouldn't be surprised if it was coming from the A/C compressor either, there's a wire nut on one of those wires from a previous owner. No idea why it's like that.
I won't 100% rule out the CVVT hub either, that makes a grinding noise on startup sometimes. However the buzz seems to be ahead of that area.
Wasamee
Year and Model: 2000 S80 T6
Post by Wasamee »
Have you made any progress with this issue? I have a 2000 S80 T6 that makes that exact same sound.
bmdubya1198
That’s interesting. I actually ended up rebuilding my original ETM with the Sacer contactless TPS, but the noise is still there. I don’t think it’s the ETM.
It sounds like it’s closer to the belts than the throttle, but it’s very hard to tell.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
bmdubya1198 wrote: 27 Apr 2019, 20:25 It sounds like it’s closer to the belts than the throttle, but it’s very hard to tell.
Have you tried taking the serpentine belt off, starting it up to see if the noise stops?
Active
Past
bmdubya1198
RickHaleParker wrote: 27 Apr 2019, 20:47 Have you tried taking the serpentine belt off, starting it up to see if the noise stops?
I have not, but I’ll give that a try.
Wasamee
Post by Wasamee »
It seems to be coming from the back of the engine near the passenger side.
bmdubya1198
Wasamee wrote: 28 Apr 2019, 00:42 It seems to be coming from the back of the engine near the passenger side.
Have you checked for any vacuum leaks back there? Sometimes that can cause a whistling noise.
