I'm familiar with that noise, but I don't think that's what it is. It's similar, but the noise goes up and down, unlike the ETM noise. I can still hear the ETM though, so I'm pretty sure it's not the same noise.scot850 wrote: 16 Apr 2019, 17:20 The ETM initialises when you switch the ignition on. It whines and buzzes but for only a few seconds or so. If it continues to do so it be it is failing.
2000 V70R Whining/Buzzing Noise in Engine Bay
CVVT – What They Do & Why
- Has thanked: 316 times
- Been thanked: 531 times
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
It sounds like bearing clatter to me. I hear metal rubbing. It sounds very similar to the noises my belt tensioners made before my timing belt water pump debacle. But this is all speculation from your video! I'd pull the t/belt cover and see if it gets louder.
- Been thanked: 4068 times
No, its a high pitched, like 1kHz buzz.
Im thinking alternator or possibly CVVT hub wear noise.
Yeah, it's definitely not mechanical like a bearing.
I listened to it this morning, thinking it may be the ETM as I listened in that area, but I definitely hear it most around the alternator area. Maybe it's the alternator, who knows. I'll take a closer listen this afternoon. I wouldn't be surprised if it was coming from the A/C compressor either, there's a wire nut on one of those wires from a previous owner. No idea why it's like that.
I won't 100% rule out the CVVT hub either, that makes a grinding noise on startup sometimes. However the buzz seems to be ahead of that area.
That’s interesting. I actually ended up rebuilding my original ETM with the Sacer contactless TPS, but the noise is still there. I don’t think it’s the ETM.
It sounds like it’s closer to the belts than the throttle, but it’s very hard to tell.
- RickHaleParker
- Been thanked: 979 times
Have you tried taking the serpentine belt off, starting it up to see if the noise stops?bmdubya1198 wrote: 27 Apr 2019, 20:25 It sounds like it’s closer to the belts than the throttle, but it’s very hard to tell.
Active
Past
Past
I have not, but I’ll give that a try.RickHaleParker wrote: 27 Apr 2019, 20:47 Have you tried taking the serpentine belt off, starting it up to see if the noise stops?
Have you checked for any vacuum leaks back there? Sometimes that can cause a whistling noise.Wasamee wrote: 28 Apr 2019, 00:42 It seems to be coming from the back of the engine near the passenger side.
- 1865 Views
Last post by bmdubya1198
- 9 Replies
- 2838 Views
Last post by Baptiste1106
- 2445 Views
Last post by Ou2mame
- 4038 Views
Last post by SimLyons
- 9 Replies
- 4758 Views
Last post by plafratt
