Radiator fan runs continuously
BryonTheCanadian
- Year and Model: 2006 XC70
- Been thanked: 2 times
Hi team my rad fan is now running on high from the second i switch on the car cold... If read it could be a defective part on the fan unit or high pressure switch on AC condenser... My Ac does not seem to be working so could be that.. Is there an easy way to disable the high pressure sensor to remove it from the equation? to see if its the Fan electronics... or other ideas B
- RickHaleParker
- Been thanked: 977 times
1. Disconnect the wire to the A/C clutch so that it cannot be engaged.BryonTheCanadian wrote: 23 Apr 2019, 11:23 Is there an easy way to disable the high pressure sensor to remove it from the equation?
2. Pull the wires on the A/C pressure switch and put a jumper across the two wires. 1/2 of a paper clip makes a good jumper.
3. Tape it so it does not get shorted.
If the fan runs correctly you found the source of the problem and can run this way until you get the A/C fixed.
Active
Past
Past
BryonTheCanadian
No have not checked much out. seems it could be 1 of two things either Fan switch or high pressure sensor on AC
BryonTheCanadian
Thanks Rick where would the AC pressure switch be located... ThanxRickHaleParker wrote: 23 Apr 2019, 11:401. Disconnect the wire to the A/C clutch so that it cannot be engaged.BryonTheCanadian wrote: 23 Apr 2019, 11:23 Is there an easy way to disable the high pressure sensor to remove it from the equation?
- 26 Replies
- 4191 Views
- 1915 Views
Last post by Earn_est_89
- 1148 Views
- 5700 Views
Last post by oragex
- 1386 Views
