The Official VOLVO SNAKE MYSTERY THREAD 8645401 [photo] - What Is It And Where Does It Go?
- RickHaleParker
- Been thanked: 978 times
I found a post on another website where somebody did the timing belt on a 2005 S60R at had that part leftover when they where done.
Active
Past
Past
It’s the rare Swedish windshield viper washer snake, often found near the serpent -tine belt
Renamed thread as I still have no idea where this part goes or anything other than 'air duct'all2many wrote: 25 Apr 2019, 16:35 Found this in trunk under the spare . Have no idea where it belongs seems to be a air duct????
I found no provision for it on my DENSO ECU box on my P2 - but that is where it has to be.
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
I still believe it is part of hvac ducting inside the cabin compartment. Looks similar to the vents that direct air to rear seats in my cars. They run along the tranny hump, under the carpet. Could be a vent that is under dash also.
- RickHaleParker
I think I know where to look. Behind the Engine coolant Reservoir and the Power Steering Fluid reservoir.
Lift out the two reservoirs, I think you will find a vent hole in the sheet metal for one end, the other end connects to the back of the ECM box.
Active
Past
Past
- June
- Has thanked: 523 times
- Been thanked: 261 times
It is the passenger side drain for the cowl. It connects to the firewall behind the strut tower. Being in a tight spot I had to take pictures at different angles to capture it for you. If a mechanic did not reattach during a timing belt service they were a hack and I would not trust the work. I have seen that drainpipe off my car during both timing belt services. Both done by my Volvo dealer so pipe was put back properly. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
June for the win!!
Where do I send the box of snakes prize ??
- 33 Replies
- 11413 Views
- 1385 Views
Last post by wanderdüne
- 31 Replies
- 13420 Views
Last post by ToriWhite
- 2202 Views
Last post by Ozark Lee
- 9 Replies
- 12988 Views
