ECM-6300 and ECM-6B00 2000 V70R [BAD Battery to fusebox supply cable!] EPIC Troubleshooting Topic is solved
- Been thanked: 4071 times
Bulbs were confirmed good above by lighting them up in VIDA
- RickHaleParker
- Been thanked: 980 times
Some times the filaments break then reconnect. Have you not had a light bulb you could tap and make it flicker?
The two codes are listed as Intermittent fault.
Active
Past
Past
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
They both have listings for both permanent and intermittent faults.
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- RickHaleParker
Same difference.Sommerfeldt wrote: 01 May 2019, 00:59 They both have listings for both permanent and intermittent faults.
Active
Past
Past
Sommerfeldt
If so, how was it relevant that they're listed as intermittent, then?
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- RickHaleParker
Same difference meaning:Sommerfeldt wrote: 01 May 2019, 02:00 If so, how was it relevant that they're listed as intermittent, then?
By my statement it should be checked for intermittence because it might be an intermittent fault.
By your statement it should be checked for intermittence because it might be an intermittent fault.
Active
Past
Past
Sommerfeldt
And how would one go about doing that, when there's no cause to be found? I'm pretty sure bmdubya has enough wits about him to try and clear codes and see what comes back. It's the first step in any and all fault tracing.RickHaleParker wrote: 01 May 2019, 02:43 Same difference meaning:
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- RickHaleParker
If it is permanent it will come back. If it is intermittence it will come back.Sommerfeldt wrote: 01 May 2019, 02:52 And how would one go about doing that, when there's no cause to be found? I'm pretty sure bmdubya has enough wits about him to try and clear codes and see what comes back. It's the first step in any and all fault tracing.
Clearing the codes gets rid of artifacts not intermittent faults.
Active
Past
Past
I’m assuming that the bulb on steady in Vida and flickering on error code is reproducible, which points away from an intermittent bulb fault. Isn’t there an actually ECM code for the CEL bulb, too?
You guys are both highland skilled detail oriented nit pickers which is why you-plural excel as troubleshooters, even if you talk past each other a bit
- Has thanked: 311 times
- Been thanked: 817 times
Neither is picking nits this time around, one of them is just never, ever wrong ... even when he obviously is.
- 838 Views
Last post by jonesg
- 16 Replies
- 4232 Views
Last post by daninater
- 11 Replies
- 9045 Views
Last post by jessefox1092
- 5467 Views
Last post by jonesg
- 3917 Views
Last post by PixelDust
