Turbo overrun boost noise?
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Should an 850T (1994) on overrun make an audible blow-off valve noise? ....FFT-FF-FF-FF-FF-FF ....or CH CH CH CH CH? You've heard it on Subaru rally cars.
I don't remember it ever before. Our system is a bypass valve, not a blow-off valve, correct? At WOT or near it, accelerate from low speed, let off the throttle - I get the FT FT FT FT noise from under the hood.
I'm wondering if there's a intercooler hose leak, or a turbo controller issue, or a vacuum line leak? I'm also trying to diagnose a recurring but inconsistent acceleration stumble and wondering if it's related.
The only code it has is EGR Flow Too Low, which it's had for a long time. I've checked the manifold opening and it's clear, I've cleaned the EGR, I've sucked on the diaphragm and it clicks. So I don't know what that's about.
I searched and found a thread on 850 vac lines, so I should check those. I just replaced these on the P2, and bought extra for this car.
viewtopic.php?f=1&t=63615
Thanks for any advice -
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 85 times
Post by hausmeister »
Well what to answer...
Stock the t5 is pretty silent imo. You can hear the turbo spool a bit (at least on mine) and during boost mabe a refined wooshing as in a lot of airflow. I don't really hear the bypass valve when it recirulates, maybe a little bit, I don't recall...
Some time ago my plastic intake hose failed near the turbo, you could hear it nicely then. But you would really have to listen for it witn the windows down I would say.
If you get funny noises chances are something is wrong. The turbo farting noise (wu wu wu wuu...) could be a faulty bypass valve. Or maybe a loose hose on it. Or a split hose anywhere...
Whatever it is, you should check all hoses and maybe do a pressure/leak test...
850 T5-R '95 auto Image
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
A leak in the intercooler hose will not allow pressure to build and therefore, no boost. I also would check for leaks in the 3 vacuum hoses to the turbo, as well as the airfilter to turbo feed.
Klaus
Has thanked: 1611 times
Been thanked: 4072 times
I heard a lot of monkey chattering from my turbo when I got the hoses mixed up
I was dumping excess boost into the manifold, and had the snorkel vacuum connection onto the Blow off valve.
Chattered whenever I lifted.
Wizechatmanager helped me get them right
When troubleshooting remember boost is controlled by ECU, not revs. You can race your engine all you want in neutral, it won’t boost
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Strictly speaking, we have a recirculating bypass valve. I've only ever heard them make whoosing noise, like they should. If you're getting Subaru noises or turbo chatter, that's boost surge. Is your CBV blocked or stuck somehow?
- S
[Sold] '97 S70 T5
BlackBart
Post by BlackBart »
Thanks everyone -
I'll check on that when I change the small vac lines. Interesting to note there's no boost in neutral / no load. So you're not going to hear or see anything from underneath to find a leak.
Mr Abscate -
WCM? RWCM? Royal Wellesley College of Music?
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
BlackBart wrote: 01 May 2019, 09:49 Thanks everyone -
Mr Abscate -
^^This guy =)
2023 Lexus RZ450e -66k
BlackBart
Post by BlackBart »
I actually don't know what RWCM stands for.....
I looked up Compressor Bypass Valve!
BlackBart wrote: 01 May 2019, 11:23 I actually don't know what RWCM stands for.....
Sorry about that - I had the worst sleepless night last night after a redeye flight - every muscle ached, and the Aleve I took sent me into stomach cramps. I slept downstairs with the dogs rather than P&M and keep the better half up all night.
BlackBart
Post by BlackBart »
Obviously from your stressful recital at the Royal Wellesly College of Music!
Take care of yourself!
PS - Ohh, that's a person, got it.
Nice to meet you Mr Wizechatmgr.
