Cheap Timing Belt Discussion
SpooliWagonMan
Year and Model: 2000 V70
Has thanked: 7 times
Post by SpooliWagonMan »
Hi all
This is my first post on here, and I would just like to get some opinions on my situation. Last year in July I changed my 2000 V70 XC SE's timing belt in an IHOP parking lot in Georgia at 2 am, and the next day it took me to Texas. Earlier that year I had replaced my 96 Integra's belt too. This past winter the Integra's belt broke :shock: :cry: It is a non interference engine, so I just threw a new one on and kept truckin. That said, I'm aware my V70 is not so forgiving. Both kits were cheap af, but from different sites. Now I'm super worried. So for the people on here who have ran with cheap belts or not, should I just go and get an expensive kit and throw it on asap?
The car has +225k on it now, is my daily, and is super solid. I want to get it to 400k, but if my cheapness grenades the poor thing that wont happen.
Thanks all!
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Can't stress this enough: Genuine or original equipment manufacturer only for the timing service! The $200-250 spent is good insurance to keep your car out of the scrapyard for the next 80k+ miles.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
June
Has thanked: 523 times
Been thanked: 261 times
Post by June »
WhatAmIDoing wrote: 01 May 2019, 18:45 Can't stress this enough: Genuine or original equipment manufacturer only for the timing service! The $200-250 spent is good insurance to keep your car out of the scrapyard for the next 80k+ miles.
Including waterpump OEM or genuine Volvo only. Your waterpump is to be changed every other belt service. So at 200K it should have been changed.
Personally my car is on its second belt and I had the waterpump replaced both times. Also front crank and cam seals were replaced on my car both times.
According to my dealer mechanic Volvo factory belts rarely fail, it's the tensioner, pulley, or waterpump that usually fails causing the belt to jump.
I would get that cheap belt out of there and install a Volvo belt kit with crank seal and waterpump. So you can drive the next 100K without worrying. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Cheap belts on an interference engine are cheap not cost effective. ASAP, get a cost effective Volvo or OEM and do a timing belt service, before you lose it all.
SpooliWagonMan
I should have mentioned I did the water pump and pulleys too, my bad. Thank you all for the advice. When I have an income again this summer, I think I'll make getting a good OEM kit on the car a priority.
June
Post by June »
SpooliWagonMan wrote: 01 May 2019, 19:34 I should have mentioned I did the water pump and pulleys too, my bad. Thank you all for the advice. When I have an income again this summer, I think I'll make getting a good OEM kit on the car a priority.
Aftermarket waterpumps have been known to fail in as little as 20K miles. If it wasn't Volvo replace it. June
My Volvo cars owned
1996 960 ordered
SpooliWagonMan
Ah! you have heightened my sense of urgency a bit. Could you direct me to the best place to buy a kit?
June
Post by June »
If you don't buy parts from your local Volvo dealer, than there are online retailers such as the ones that advertise here on MVS, or places like Volvo oem parts direct which is a Volvo dealer up North but sells at discounted prices. Don't use Ebay or accept a open box as either could have had the factory Volvo parts swapped out. When it comes to the timing belt and anything it touches must be genuine.
You can cut corners in other areas of service. I have read woes here too often with aftermarket belt kits and waterpumps failing early. June
My Volvo cars owned
1996 960 ordered
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Agree with all the comments above.
If you don't know the brand of water pump that went into your car, replace it immediately with an Aisin brand pump (this is OEM) along with the TB and components OEM only.
Take it from someone who spent $4000+ for a replacement engine after the cheapo WP failed at 130k on my 98' V70XC.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
RickHaleParker
Timing belt: Volvo or Contitech (Continental).
Water pump: Volvo or Aisin.
Idler & Tensioner: Volvo or INA.
