IPD sale Volvo Parts
Did you know? 🤔
Fuel Pump Relay Location to the 2001 XC70
2001 - 2007 XC-70
freshwesty
Year and Model: 2001 V70XC
Has thanked: 3 times
Been thanked: 0
United States of America
freshwesty
Post by freshwesty » Thu May 02, 2019 8:51 am
Hello,
I recently bought a 2001 V70XC from a friend who parked it after it died. I believe it to be a relay or fuel pump. I have been searching high and wide for this relay location, and it appears to be unique to the 2001 XC with the 2.4L Turbo???
I found the relay diagram on this site and was able to locate it under the driver side dash in CIM12. I swapped it out with a fog light relay just to test, but still nothing. I plan to pull the pump this weekend and see if the connector is getting power to it, however I just want to make sure I am covering my bases as there is a lot of talk about the Red, 103 relay on these vehicles that usually needs to be replaced. However, it has a female connector and I can't seem to locate where it should go, or maybe it's not right for my vehicle. Does anyone know where this is located or am I way off on this relay (photo attached).
I have ordered a new Bosch 69746 Fuel Pump (plastic tank) which I will most likely install anyways since the car has 231,000 miles on it and there is no documentation whether this has ever been replaced.
I appreciate any help on this, I have also included my VIN number if that offers any insight to my novice question. Thank you for any help on this!
VIN: YV1SZ58D611003011
VW Van and Audi RS4 lover and owner!
https://freshcoastwesty.com
oragex
Year and Model: S60 2003
Has thanked: 77 times
Been thanked: 156 times
Canada
oragex
Re: Fuel Pump Relay Location to the 2001 XC70
Post by oragex » Thu May 02, 2019 9:24 am
I've heard the 2001-2002 don't have a PEM but I might be wrong. These are the locations I'm aware off on 2003-up
The XC90 also has a location inside the left (?) rear wheel well, behind the plastic cover
The fuel pumps on these Volvo are unlike what you will find in a Honda or Ford. Volvo ones last forever and most likely the culprit is a PEM or FPS (when equipped with one). Have you checked the timing belt ? If the car stopped all of a sudden there can be other issues, such as a failed water pump or belt components, failed DEM, etc
These users thanked the author oragex for the post:
freshwesty
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
freshwesty
Been thanked: 0
freshwesty
Post by freshwesty » Thu May 02, 2019 9:43 am
I have checked the timing belt, all of that is newer and was replaced before it died, per my friend. She mentioned it would constantly sputter and sometimes die. Then one day it just wouldn't start. It turns over great though, but it appears to be lacking any fuel.
I appreciate the insight on this! All of my googling has led me to assume it may be a Relay. I have pulled every fuse and relay and all appear to be clean and no popped fuses or arc marks on the relays to show they have blown. My Audi RS4 had this type of issue last summer and with an $11 relay and 5 hours of getting to it, it fired right back up and has been running like a dream ever since. I guess I just want to verify the relay variable before ripping into the fuel pump area is all. Again, I appreciate your input on my post.
Has thanked: 185 times
Been thanked: 563 times
Trinidad & Tobago
Post by abscate » Thu May 02, 2019 12:31 pm
Hike over to Advance Auto, get a real fuel pressure gauge, and measure it at the rail. It needs to be up at 50 psi or else Baby won't run.
That will also send you down the right path of troubleshooting.
Your 2001 has a embedded fuel pump relay on the CEM, a PEM, and a modulated fuel pump
These users thanked the author abscate for the post:
freshwesty
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
freshwesty
Been thanked: 0
freshwesty
Post by freshwesty » Thu May 02, 2019 12:36 pm
Abscate, thank you so much for this info! I am on it!!
oragex
Canada
oragex
Post by oragex » Thu May 02, 2019 12:37 pm
Also have a look at the FPS in the same place, if there's one at the right end of the fuel rail. You may also have a external fuel filter, worth servicing it while there
freshwesty
goldmandan
Year and Model: 1999 S 70, 2000 V70
Has thanked: 0
Been thanked: 0
Sweden
goldmandan
Post by goldmandan » Thu May 02, 2019 1:53 pm
ABSCATE, on my 2001 S60, I have looked for the usual PEM but I cannot find it on the passenger side underneath just in front of rear wheel. Is the PEM installed elsewhere on this year? Also, is the fuel filter installed under that center panel under the car, where a driveshaft would be installed on a RWD car? Still working on the intermittent crank, no start
dan
Trinidad & Tobago
Post by abscate » Thu May 02, 2019 2:25 pm
My PEM was on top of the tank , but there is also a TSB to move it from there into the trunk area to prevent corrosion - so it can have been moved on your car.
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
