BlackBart
Has thanked: 927 times
Been thanked: 884 times
Re: What did you do to your P2 Volvo today....now sticky!!
Post by BlackBart »
I HATE it when deers do that!
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
So, the c. 90 mile round trip test drive back and forth to work reveals Ruby Red to be driving smooth as glass. I did not think it was bad before. This is spectacular. The only thing I dislike about the XC70 is the exterior styling. They are just not attractive cars.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Has thanked: 1505 times
Been thanked: 3817 times
You should have asked for Ruby Red as a P2.
That was/I said a great deal, even better than Evita! Please avoid Nissan Rogues...
BlackBart
Post by BlackBart »
abscate wrote: 03 May 2019, 03:35Please avoid Nissan Rogues...
At ALL COSTS!!
E Showell
Post by E Showell »
Yesterday, actually. First oil change on wife's newish to us 2007 S80 3.2L. Owner's manual lists sump capacity as 7.8 quarts. Should I be concerned that it took close to 8.5 qts. to reach top of dipstick fill region? I let the bulk of the fill sit overnight before topping up this a.m.
Getting the oil filter out is a bit of a trick. I never took the filter cap out of the vehicle, I just put it on its side and slid the filter and O-ring off that way. I had to lift the power steering reservoir out of the way and needed a 1/2 drive wobble joint and 10" extension to get the filter cap off with a 36 mm socket. The design is a bit of a puzzler, but I didn't take the press on engine cover off either. That might have made it easier.
'95 855 auto (sold)
BlackBart
Post by BlackBart »
That doesn't sound right. If you only put in seven and a half and it reads overfull, then it hasn't gotten into the filter yet and will come down. But if you put eight and a half qts in....then there are eight and a half qts in it. It's too full.
If the dipstick wasn't pushed all the way in, it could read too low.
Oversized filter? Holds more oil?
E Showell
Post by E Showell »
It isn't reading overfilled. I am basing the amount in the system on the amount of oil added based on a rough reading of the markings on the side of the 5 quart oil jugs from which I filled. At 7.5 quarts it was barely registering above the "twist" at the very tip of the dipstick. Took almost another full quart to get it to the "full" mark on the dipstick. Dipstick is fully seated. I checked and double checked. There are postings on other fora (forgive me father for I have sinned) suggesting that the 7.8 quarts specification for the 3.2l I6 is not accurate, and the actual amount required is closer to 9 quarts. Just wondering if that matches anyone's experience here.
'95 855 auto (sold)
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
Post by MDK »
Well boys and girls... I just did what that call a " pump down/ pump out. 2002 V70 2.4 NT. I bought 12 quart's of the aisin T1-V. Checked the dip stick..reads full at cold mark ✓
Evan , other than being on the dipstick it won’t make any difference to engine operation if you have 7,8,9 quarts/liters in the sump. Just find the amount that gets it mid range on level ground, enter it into the log, and roll. Check after a hot run, 15 minute drip down, too.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Got the brake booster seal from URO, waiting now for a moment to install it - in fact I will first practice a little at the junkyard. Have to say the quality looks good, there is some silicone grease and the pipe used to press the thing has an angled end (important) and the URO video also shows an important part about bending the lip of the seal at @2:30
https://www.ebay.com/itm/Mercedes-W212- ... 2749.l2649
