Amazon Black Friday deals
07 XC90 3.2 Oil trap loud hissing noise
Help, Advice, Owners' Discussion and DIY Tutorials on Volvo XC90s. The XC90 proved to be very popular, and very good for Volvo's sales numbers, since its introduction in model year 2003 (North America).
vmaxmike
Year and Model: 06 S60R, 07 XC90 3.2
Post by vmaxmike »
Has anyone with this model engine or newer have the loud whistling / hissing noise happen that comes from under the hood resulting presumably from a clogged oil trap box? Is it possible to clean or service it? Thanks
cuhfs
Year and Model: 850,XC70,XC90,S60,80
Been thanked: 11 times
Re: 07 XC90 3.2 Oil trap loud hissing noise
Post by cuhfs »
I do not have that engine but I would assume PCV is a routine service item
95 850 Sedan Auto Trans
98 V70 Manual Trans
01 C70 Manual Trans
03 XC70 Auto
04 C70 Auto
06 XC90 Auto (ORE)
06 S80
12 S60
96 850 Wagon Manual Trans (parts car)
vmaxmike
Re: 07 XC90 3.2 Oil trap loud hissing noise - fixed!
Post by vmaxmike »
Yes, I replaced the oil trap box with built in pvc diaphragm on top of engine and issue solved. Took 10 minutes however $180 for the new part. Naturally Volvo doesn't provide a repair kit which would allow for a cheap and easy replacement of just the rubber diaphragm (part that eventually tears and fails) and cap which pops right off with a little force. Would be nice if some after market company made these like Dorman does for VW/BMW which go for around $20!
raquette
Year and Model: 2010 xc90, 2007 xc70
Post by raquette »
on this topic, is it possible to replace the diaphragm with a part from a used cover, assuming the part can be removed from a donor vehicle and reattached?
also I've seen the pvc oil trap covers on ebay or parts sites for between $60 to $175. this is a plastic cover.
Are the cheaper covers acceptable?
ggleavitt
Year and Model: XC90 05-2.5T, 08-V8S
Been thanked: 61 times
Post by ggleavitt »
Internet search "B6324S pcv diaphragm replacement", been seeing just the diaphragm offered over the last year. Seems like it could a viable alternative to replacing the cover outright.
2005 2.5T AWD-201k
2008 V8 AWD Sport-134k
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 26 times
Been thanked: 46 times
Post by pgill »
All,
It may be cheaper to buy the part from Land Rover
Note: the 2008 - 2012 Land Rover LR2 uses the Volvo 3.2
The Land Rover part number is LR023777 it is the same vendor, same part as the Volvo Part it just comes in a Land Rover box
Note: this is for the 3.2 and not the 3.0T
A link that shows what needs to be replaced
http://www.freel2.com/forum/topic32107.html
If you are really ambitious you can try to replace just the diaphragm
Based on what I've read you will need a heat gun
https://www.ebay.com/itm/172267660060?ul_noapp=true
If you just replace the diaphram please let us know how you did it
Thanks
Paul
raquette
Post by raquette »
I ordered an aftermarket part off ebay. we'll see how this works.
raquette
Post by raquette »
installed the aftermarket cover and was i surprised when the bolt holes were slightly off - the repo part is not made exactly as it should be. just what i was concerned about by this $42 part.
so all but 4 bolts lined up at one end end with the threads. there I popped out the aluminum inserts, cut them in half with the cut off wheel, and reinstalled to get some stretch in the plastic opening that allowed the 4 bolts to line up.
cheap was not the way to go, but the hiss is gone!
JohninMaine
Year and Model: 2010 XC70
Post by JohninMaine »
Hi, raquette and pgill:
I am attempting to replace the diaphragm. Thank you both for your information. You mentioned the use of a heat gun. Is that needed in order to soften the cap so that it can be removed? Sadly I tried to pry it a bit too hard and some of the plastic around the edge broke off. Getting the cap to pop off is not so easy. Any suggestions would be much appreciated.
Also, raquette, I just ordered an aftermarket piece for $40 from a Chinese distributor. I'm now worried that I will get the part that has the misaligned holes, given the low price. Do you recall where you purchased yours?
Thank you! John
JohninMaine
Here is an image of the item that I ordered. I'm worried that the holes won't align.
https://www.aliexpress.com/i/32978391356.html
