braking pulse.
Dreydubs
Year and Model:
Post by Dreydubs »
When Im braking hard, I can feel a pulsing feel in my brakes. Whats wrong?
bekko
Year and Model:
Post by bekko »
might just be your Antilock Braking System kicking in.
-steve
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
If the pulsing is very fast then it is the ABS. If it is a slower pulse that corresponds to each revolution of the tires then you have warped brake rotors.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You need new rotors
chuckcintron
Year and Model:
Post by chuckcintron »
Besides rotors, anything that introduces play in the suspension can contribute to this. I had perfectly fine rotors, but had a nasty pulsation due to a broken spring seat.
Any of that stuff at the top side of the strut, as well as a (badly) worn wheel bearing can introduce a pulsation when braking.
-Chuck
1997 855GLT
Tsquared
Year and Model: 11 C30
Post by Tsquared »
Also realize that if the ABS sensor loads up with metal filings it will give a false positive and set off the ABS pump. This vibration/pulsation occurs only at low speeds and can be rectified by cleaning the sensor.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
