Did you know? 🤔
Air pump '98 S70
MrAl
Year and Model: v70, 1998
Has thanked: 0
Been thanked: 6 times
United States of America
MrAl
Re: Air pump '98 S70
Post by MrAl » Fri May 03, 2019 6:43 am
Hello there,
I have a 1998 v70 and mine does the same thing and always has since i got the car back some years ago. Is it normal? Well i cant say if it is normal for this make/model/year car in general, but i can say that it is normal for my particular car because i've always seen this behavior since i've had it with some variations as explained below.
It seems to be random though. Sometimes when i get to the first stop sign on my way out somewhere it comes on, sometimes not. Sometimes at a red light it comes on, sometimes not.
If i had to guess, and this is just a guess, it may be checking the system at random times under different conditions, and if it saw a problem at some point it might repeat the test under the same conditions. When i had trouble with my air pump i noticed it came on a lot more after i fixed the problem, but now it is much less.
Then again it could be that it comes on for some other reason because it detected something else that the air pump is used for.
These users thanked the author MrAl for the post:
1998 v70 on the road since April 2nd, 2015
Has thanked: 72 times
Been thanked: 227 times
Post by erikv11 » Fri May 03, 2019 8:05 am
Thanks MrAl, that is helpful to know.
RickHaleParker wrote:
Fri May 03, 2019 4:08 am
abscate wrote:
Fri May 03, 2019 3:22 am
Can we agree it’s a common occurrence, without the judgemental “ normal” or “abnormal”?
Clearly not unheard of but not enough data to declare it common. ...
The data are there, that is the point of my posts. Dogmatism does not trump empiricism.
I doubt it is related to brown out as common as it is, I think it is part of the routine.
'96 855 NA, 140k
'98 S70 NA, 210k (living out west)
'98 V70, T5 tune-injectors-turbo, LPT engine, 280k
'06 S60 R, 160k
Has thanked: 230 times
Been thanked: 760 times
Trinidad & Tobago
Post by abscate » Fri May 03, 2019 8:12 am
Source code of the ECM with the run conditions are the only way to firmly put the design intent question to bed. Ill bet there as many cars that don't run SAS after start as not; of course, a plethora of variables muddy the water as to why this happens.
Hey, I used a semi-colon!
Link To Volvo Glossary
Post by erikv11 » Fri May 03, 2019 10:47 am
Or we could ask jimmy57!
'96 855 NA, 140k
'06 S60 R, 160k
MrAl
Has thanked: 0
MrAl
Post by MrAl » Fri May 03, 2019 11:40 am
Hi,
That's an interesting point about the brownout, but since i had my new battery i dont see any difference that i can notice. I know there was a difference in battery voltage too with the old battery compared to the new one because i keep an analog meter connected at all times. When i turn the heater on i see the voltage dip and with the old battery it would dip really low but with the new battery it dips only slightly. But through it all the air pump seems to act the same.
I dont have any data on how much the battery voltage dip affects the computer though so all i can do is state my experience with it so far. i have had the new battery for a couple months now.
RickHaleParker
Has thanked: 3 times
Been thanked: 374 times
RickHaleParker
Post by RickHaleParker » Fri May 03, 2019 2:48 pm
MadeInJapan's observations in the other post could be the results of several things.
1. It could be the ECM sending a spurious command.
2. As I stated earlier, it could be the +12V on the coil shorting to another +12V.
The source of this could be right there at the pump relay.
A. Sockets can develop intermittent shorts.
B. Relays can develop internal intermittent shorts.
There is a +12 for the switch pole at the relay.
3. Wiring looms can develop intermittent shorts anywhere along their length.
My '98 C70 SAS does not activate after the initial warm up.
Platform: P80 1998 C70, B5234T3, 16T, AW50-42, Bosch Motronic 4.4, Special Edition package, Plant: Uddevalla Sweden.
Platform: X40 (Nedcar) 2003 S40, B4204T3, 14T twin scroll AW55-50/51SN, Siemens EMS 2000. Plant: Born Netherlands.
Platform P2 2005 XC90 T6 Executive, B6294T, 4T65 AWD, Bosch Motronic 7.0,
Plant Torslanda Sweden.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri May 03, 2019 3:15 pm
It may not be the voltage level, it could be the slew rate of the fall or rise.
Some digital events are triggered by the Signal edge.
RickHaleParker
RickHaleParker
Post by RickHaleParker » Fri May 03, 2019 6:10 pm
I would start with tapping on the relay to see if the pump comes on.
Inspect the socket and looms for damage.
crlande
Year and Model: 240DL;850;S70
Has thanked: 0
Been thanked: 16 times
crlande
Post by crlande » Fri May 03, 2019 7:58 pm
That is my game plan, mess with relay and look for vac leaks. Quite the informational topic. Detailed explanation of system function, electrical tech, past posts, philosophy, and punctuation excitement. All from some the heavy hitters on MVS.
