Genuine Volvo ATF is NOT Mobil 3309...
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
The original design uses Arduino Due, Due CAN-shield (by togglebit) and 4DSystems uLCD-24PT. I'm working on a cheaper design: ESP32, regular MCP2515 shields, newer-bigger-cheaper display, but my off-work hours are badly oversubscribed.
You also need a bunch of DB-9/DB-25 connectors, CAT-5 cable (not a solid core!) and some other small stuff, like heat shrink tubing, etc.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
SuperHerman wrote: 30 Apr 2019, 16:49 Question: Is Adaptation needed after doing a fluid change? Answer, which is consistent with what I understand, is yes. Being lazy rather than boot up VIDA, I searched. See here: http://www.volvoxc.com/forums/showthrea ... Adaptation
Herman, that link seems to point to the idea of not resetting/relearning the adaptations just because of fluid change. That's what JRL and I think vtl seem to be saying on that thread. But correct me if I understood the wrong way.
All in all, after installing new Rostra solenoids, I found the relearn process very difficult to complete. In fact, my car didn't even complete that process and I took a good 1:30h driving the car and waiting for the triangle light: some shift points never got to light on so were not learned during that process. Good to think of it, this relearn process is not that easy to accomplish - well at least not with just new main solenoids, perhaps it would work easier with a whole new valve body.
IslandV70
- Year and Model: 2005 V70 2.4
- Has thanked: 2 times
- Been thanked: 3 times
Would this be a starting point??vtl wrote: 01 May 2019, 09:25 The original design uses Arduino Due, Due CAN-shield (by togglebit) and 4DSystems uLCD-24PT. I'm working on a cheaper design: ESP32, regular MCP2515 shields, newer-bigger-cheaper display, but my off-work hours are badly oversubscribed.
https://freematics.com/products/arduino ... ics-kit-1/
maybe this needs another thread. I love your display.
vtl
No, Nano can't fit in all of the fatty software, plus it does not have IO pins.IslandV70 wrote: 01 May 2019, 11:09 Would this be a starting point??
This can be a starting point: http://togglebit.net/product/arduino-due-car-kit/
Or let's do a ESP32 version, it is cheaper ($11 for the MCU itself, like $1.5 for one CAN-controller, need two of them). I'm barely motivated to finish it otherwise, 'cause I already have a working Due version
Yeah, new thread is good. Wanna start?
- Been thanked: 4068 times
Give me a thread title and I’ll cull this one out guys
Thanks for self moderating, awesome...
FOUNd it, never mind
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
My theory the ATF is still coming out dark after several drains and 1 gibbons flush is the BG Quick Clean. It is a harsh cleanser used for only several minutes of shifting with a warm engine. I added the BG ATC+ Lube Guard after those drains to neutralize the solvent.XC70Rider wrote: 30 Apr 2019, 09:24 During the drains I did in October 2018 and January 2019 I added BG Quickclean into the warm engine and manually shifted through all gears before the drain. I then added in the full 11oz of BG ATC Plus during those fills but it made no difference.
I got 4L of Genuine Valvoline ATF and Lubeguard HFM delivered today. Before I add in the Genuine Volvo ATF I'm going to add in the half priced Idemitsu TLS again to get more of the gunk cleansed out.
I've driven the wagon 188 miles since last weekends AT sump drain. After I drain again tomorrow I'll add in 3.5 quarts of Idemtisu TLS with a few ounces of Lubeguard HFM. After driving for at least 100+ miles I'll drain it out and study the contents of the warm ATF. If it appears cleaner I'll add in 3.5 quarts of the Genuine Volvo ATF with a few ounces of Lubeguard HFM.
- oragex
I had a lot of troubles measuring the level with the Valvoline stuff. In winter there would be no traction on cold mornings - fluid would shrink and be too low inside the torque converter, and in hot summer days the level would show way above hot level. Got rid of it and put Type IV from Toyota, those issues all gone.
XC70Rider
It appears Toyota Type IV and Idemitsu TLS (Toyota/Lexus/Scion) are the same ATFs. The Idemitsu TLS has 'Type IV' written on the container. As other members have mentioned Idemitsu TLS is the closest viscosity match to Genuine Volvo ATF. Being a thicker ATF it takes longer to pour Idemitsu TLS via the long dipstick than Mobil 3309.
I forgot to reset the fluid counter when I first switched from Mobil 3009 to Idemitsu TLS. My wagon is shifting smoother with the Idemitsu TLS now. I'm just trying Genuine Volvo ATF to see if makes a difference. If she shifts fine then I'll let run for 10K+ more miles before the next AT sump drain.
