Radio says "off" 94 Volvo 850
jjss70
- Year and Model: 99 s70 Turbo AWD
- Has thanked: 7 times
To: bsgoldn : From: jjss70: Try removing the negative cable at your battery, give it a minute to reset and replace the negative cable back on your battery. Turn your ignition switch on to the first indent or mark on your steering column at ignition switch and make sure nothing else is draining your battery down other than the digital readout of the word "OFF" by your radio. Wait 2 hours and when you see your radio after 2 hours it will be asking you for the code again. You only get three attempts at providing the correct code. Good Luck, jjss70.
jjss70
To: Herr Gruyere: From: jjss70: Try removing the negative cable at your battery, give it a minute to reset and replace the negative cable back on your battery. Turn your ignition switch on to the first indent or mark on your steering column at ignition switch and make sure nothing else is draining your battery down other than the digital readout of the word "OFF" by your radio. Wait 2 hours and when you see your radio after 2 hours it will be asking you for the code again. You only get three attempts at providing the correct code. Good Luck, jjss70.
- RickHaleParker
- Been thanked: 980 times
From the 1997 850 owners manual.Doncrawford1766 wrote: 03 May 2019, 19:18 Yea my radio says off on my 97 volvo 850 what can i do to get it to play
If an incorrect code has been entered "EEEE" is displayed. Enter the correct code.
After three unsuccessful coding attempts, the set will lock and remain locked for two hours. "OFF" is displayed.
During this waiting period:
1.The battery must be connected
2. The ignition key must be turned to position I (ACC (I) not ON (II))
3. The unit must be turned on
4. Make sure the headlights are turned off to help prevent battery drain
(please refer to page 2:8 for information on turning the headlights off)*.
5. Enter the code again once this time has elapsed. ( The display reverts to CODE )
* If your Daytime Running Lamps are active, what looks like a screw in the corner of your light switch is in fact the DRL switch. Turn it with a Jeweler's screwdriver.
(|) Automatic daytime running lights
(/) Automatic daytime running lights (will also function when the headlight switch is in position )
(\) All lights off (daytime running light function disabled)
Active
Past
Past
- Has thanked: 1611 times
- Been thanked: 4075 times
When my car was stuck in this mode , I told the girls this was a special station only men could hear
I paid dearly for that, later
- RickHaleParker
OFF = Only For Father.abscate wrote: 04 May 2019, 02:45 When my car was stuck in this mode , I told the girls this was a special station only men could hear
Active
Past
Past
wrybread
- Has thanked: 15 times
- Been thanked: 15 times
This happened to me when I disconnected power and entered a wrong (guessed) code 3 times. It said "off" and I needed to leave the key in the 1 position for a bit over 2 hours. Frustrating.
The good news for me was it was easy to get the code. I went to this page:
http://volvo.custhelp.com/app/answers/d ... radio-code
And entered my VIN, and it gave me the code right away.
Hopefully there's a way to get the code without the VIN, but I didn't investigate that.
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
- 23 Replies
- 6254 Views
Last post by HerrGruyere
- 1445 Views
Last post by Ozark Lee
- 23 Replies
- 5316 Views
Last post by oragex
- 9 Replies
- 2151 Views
Last post by theWIFES_S70
- 1096 Views
Last post by jimmy57
