IPD sale Volvo Parts
Did you know? 🤔
Genuine Volvo ATF is NOT Mobil 3309...
2001 - 2007 XC-70
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 23 times
United States of America
vtl
Re: Genuine Volvo ATF is NOT Mobil 3309...
Post by vtl » Wed May 01, 2019 9:22 am
$57.99 for 4 liters (1161640) at FCP: https://www.fcpeuro.com/products/automa ... er-1161640
These users thanked the author vtl for the post:
IslandV70
2005 XC70 250k
2016 XC60 40k
vtl
vtl
Post by vtl » Wed May 01, 2019 9:25 am
The original design uses Arduino Due, Due CAN-shield (by togglebit) and 4DSystems uLCD-24PT. I'm working on a cheaper design: ESP32, regular MCP2515 shields, newer-bigger-cheaper display, but my off-work hours are badly oversubscribed.
You also need a bunch of DB-9/DB-25 connectors, CAT-5 cable (not a solid core!) and some other small stuff, like heat shrink tubing, etc.
2005 XC70 250k
2016 XC60 40k
oragex
Year and Model: S60 2003
Has thanked: 78 times
Been thanked: 160 times
Canada
oragex
Post by oragex » Wed May 01, 2019 10:26 am
SuperHerman wrote:
Tue Apr 30, 2019 4:49 pm
Question: Is Adaptation needed after doing a fluid change? Answer, which is consistent with what I understand, is yes. Being lazy rather than boot up VIDA, I searched. See here: http://www.volvoxc.com/forums/showthrea ... Adaptation
Herman, that link seems to point to the idea of not resetting/relearning the adaptations just because of fluid change. That's what JRL and I think vtl seem to be saying on that thread. But correct me if I understood the wrong way.
All in all, after installing new Rostra solenoids, I found the relearn process very difficult to complete. In fact, my car didn't even complete that process and I took a good 1:30h driving the car and waiting for the triangle light: some shift points never got to light on so were not learned during that process. Good to think of it, this relearn process is not that easy to accomplish - well at least not with just new main solenoids, perhaps it would work easier with a whole new valve body.
2003 2.4i S60 automatic 125k miles
DIY Volvo repairs videos https://www.youtube.com/playlist?list=P ... s0FSVSOT_c
IslandV70
Year and Model: 2005 V70 2.4
Has thanked: 2 times
IslandV70
Post by IslandV70 » Wed May 01, 2019 11:09 am
Would this be a starting point??
https://freematics.com/products/arduino ... ics-kit-1/
maybe this needs another thread. I love your display.
vtl
vtl
Post by vtl » Wed May 01, 2019 11:18 am
No, Nano can't fit in all of the fatty software, plus it does not have IO pins.
This can be a starting point: http://togglebit.net/product/arduino-due-car-kit/
Or let's do a ESP32 version, it is cheaper ($11 for the MCU itself, like $1.5 for one CAN-controller, need two of them). I'm barely motivated to finish it otherwise, 'cause I already have a working Due version ;)
Yeah, new thread is good. Wanna start?
2005 XC70 250k
2016 XC60 40k
Has thanked: 185 times
Been thanked: 575 times
Trinidad & Tobago
Post by abscate » Thu May 02, 2019 4:24 am
Give me a thread title and I’ll cull this one out guys
Thanks for self moderating, awesome...
1 SWMBO for 30 years
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
6 Perfect Ladies in waiting
7 Drivers
8 Boats- with a big pointy metal thing on top
1999 V70 T5M 56 2005 V70 NA M56 VWs BMW
Trinidad & Tobago
Post by abscate » Thu May 02, 2019 4:27 am
FOUNd it, never mind
2 Volvos
3 VWs
4 Careers
5 cats/dogs/gears
7 Drivers
XC70Rider
Year and Model: 2007 XC70
Has thanked: 20 times
Been thanked: 13 times
XC70Rider
Post by XC70Rider » Fri May 03, 2019 5:57 pm
XC70Rider wrote:
Tue Apr 30, 2019 9:24 am
During the drains I did in October 2018 and January 2019 I added BG Quickclean into the warm engine and manually shifted through all gears before the drain. I then added in the full 11oz of BG ATC Plus during those fills but it made no difference.
My theory the ATF is still coming out dark after several drains and 1 gibbons flush is the BG Quick Clean. It is a harsh cleanser used for only several minutes of shifting with a warm engine. I added the BG ATC+ Lube Guard after those drains to neutralize the solvent.
I got 4L of Genuine Valvoline ATF and Lubeguard HFM delivered today. Before I add in the Genuine Volvo ATF I'm going to add in the half priced Idemitsu TLS again to get more of the gunk cleansed out.
I've driven the wagon 188 miles since last weekends AT sump drain. After I drain again tomorrow I'll add in 3.5 quarts of Idemtisu TLS with a few ounces of Lubeguard HFM. After driving for at least 100+ miles I'll drain it out and study the contents of the warm ATF. If it appears cleaner I'll add in 3.5 quarts of the Genuine Volvo ATF with a few ounces of Lubeguard HFM.
oragex
Canada
oragex
Post by oragex » Fri May 03, 2019 7:42 pm
I had a lot of troubles measuring the level with the Valvoline stuff. In winter there would be no traction on cold mornings - fluid would shrink and be too low inside the torque converter, and in hot summer days the level would show way above hot level. Got rid of it and put Type IV from Toyota, those issues all gone.
XC70Rider
XC70Rider
Post by XC70Rider » Sat May 04, 2019 8:53 am
It appears Toyota Type IV and Idemitsu TLS (Toyota/Lexus/Scion) are the same ATFs. The Idemitsu TLS has 'Type IV' written on the container. As other members have mentioned Idemitsu TLS is the closest viscosity match to Genuine Volvo ATF. Being a thicker ATF it takes longer to pour Idemitsu TLS via the long dipstick than Mobil 3309.
I forgot to reset the fluid counter when I first switched from Mobil 3009 to Idemitsu TLS. My wagon is shifting smoother with the Idemitsu TLS now. I'm just trying Genuine Volvo ATF to see if makes a difference. If she shifts fine then I'll let run for 10K+ more miles before the next AT sump drain.
