Strut Question for the guru: 2004 V70 vs 2002-2006 S60
Been thanked: 504 times
Post by cn90 »
I need to buy the quick strut Sachs 033078 (Plug-and-Plug) but FCP says it is out for now.
This is the quick strut I want to buy:
https://www.fcpeuro.com/products/volvo- ... sac-033078
From my extensive search using Volvo web catalog, FCP website and many Volvo dealer websites, the V70 and S60 in the P2 platform share the same:
- Strut Bearing
- Spring Seat
- Coil Spring
- Strut (Sachs or Bilstein)
What I don't understand is why Sachs says:
- 2004 V70: use Sachs 033078
- 2007 V70: use Sachs 033079
- Let's say 2004 S60: use Sachs 033083
I wonder if they are all the same stuff...
I can find some Sachs 033083 as they are still available on some websites and wonder if this S60 thingy fits in my 2004 V70...
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
We had some negative feedback with these quick struts.. not the worse, but not the best components - these have the lower quality Sachs strut on them
As for the fitments, I know Volvo has several strut numbers from 01-09, I guess variations are for fwd vs rwd cars, and maybe other factors, trims, years, etc. My only concern is I tried on my 2003 several struts and most of them had the front of the car lifted by about 1in which is not fun.
Post by cn90 »
I thought most of the complains were from Monroe and other "no-name" Chinese quick struts.
Most of the reviews on Sachs quick struts (reviews are on FCPEuro website) are good.
I'd NOT think Sachs made a whole bunch of "low-quality" Struts just for the purpose of pre-assembled struts.
Could you direct me to the negative reviews on Sachs struts?
MDK
Year and Model: 2004 S60R
Been thanked: 42 times
Post by MDK »
Well cn90..I read your post and I wanted to share with you what I did recently to my 2004 S60 R and my 2002 V70 2.4 non turbo.I bought from Erie Volvo 4 used complete strut assemblies and ditched the 4c suspension and installed 4 standard struts from a 2007 S60 AWD that Erie Volvo sent me. Then.. I had originally bought 2 lower control arms for the wagon but ended up putting them on the R car. Mix and match. MDK rolling on
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 12 times
Post by DeadEric »
A quick Google search showed that ipd has them, different ipd part number but listed as 033078 in the product attributes
IPD Item Number: 125618
Post by cn90 »
Thanks but I already called IPD last week.
They do not have it in stock.
Also, IPD web listing says 033079, but photos show one with 033078.
I personally think all these Sachs numbers I posted above are interchangeable for 2001-2007 P2 such as S60, V70 (non-R models).
But if anyone has tried this (using 033079 in a 2004 V70), I'd like to know.
I have verified all individual PNs such as spring seat, strut bearing, strut itself from different vendors, and they fit these years.
I don't know why Sachs 033079 says "From Chassis Range: 547727", whatever it means...
Has thanked: 311 times
Been thanked: 817 times
Dang this V70 is costing you a lot of $$, sorry to hear.
I also recall the negative discussion about the Sachs quick strut here at MVS, as Neil mentioned. Hit up the search button.
Post by cn90 »
Thanks all for the replies.
I did a little search on Sachs Struts with White, Blue and ? Red labels.
Confusing topic.
Mixed results, some say white label is so-so, some are very happy with quick struts (Sachs).
Anyway, I will likely do the old fashion way:
- Corteco Strut Bearing
- Sachs XC90 Spring Seat
- Bilstein TC Struts
- Lesjofors Coil Spring
DonnVa
Year and Model: 2005 XC70
Has thanked: 21 times
Been thanked: 61 times
Post by DonnVa »
cn90 wrote: 04 May 2019, 20:29 I need to buy the quick strut Sachs 033078 (Plug-and-Plug) but FCP says it is out for now.
- Strut Bearing
- Spring Seat
- Coil Spring
Try ipdusa.com and see how they reference them. In their listings their cross referencing is pretty extensive.
*Edit* I have no idea how I ended up in this thread….. I have no excuses, I don’t drink. Must be old age. 😣
2005 XC70 Cross Country 2.5T 185k miles
1962 122s 4dr 100k+ TMU
-Previous-
2007 S60 2.5T
1996 850 GLT
1974 164E
-Notable-
1983 911sc
1994 325i
2007 335 coupe
30 + other cars and trucks
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Has thanked: 7 times
Been thanked: 5 times
Post by Herb Goltz »
cn90 wrote: 05 May 2019, 07:45 I thought most of the complains were from Monroe and other "no-name" Chinese quick struts.
Some of it is here: abscate described having two spring failures (I recall that at least one just broke sitting in the driveway!):
viewtopic.php?t=100295
2012 s60 t5
2006 XC70
2004 XC70
