As a practical matter I don't think there are that many manufacturers of timing belts. Continental, Dayco, and Gates come to mind. I've put a Gates belt on a Volvo and didn't loose a minute of sleep over it.
I have never seen a belt itself just break. I'm sure it can happen but in my experience it is always something else that causes it to fail like a water pump locking up or a tensioner failing.
The real peace of mind comes when the items in the belt path are changed.
Cheap Timing Belt Discussion
- Year and Model: Many Volvos
- Been thanked: 76 times
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Last time I personally witnessed a timing belt go of it's own accord was on a K car. On a non-interference who cares, but on these, you're screwed. Better safe than sorry.
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
That's where I've seen it too: 1987 Dodge short caravan with the L4. Which is practically a K-car. I picked it up non running for $100, sometime around 2005. I felt sorry for the PO who sold it to me, his mechanic couldn't diagnose a timing belt where the teeth on the belt stripped out around the crank and was convinced that the car had an electrical/wiring loom issue under the hood and went so far as to replace the engine harness. But got hold of the wrong harness (couple of the connectors were different + several circuits were wired different). Being a non inteference engine $20 at a pick and pull for the correct harness and a new TB and it started right up.wizechatmgr wrote: 04 May 2019, 18:39 Last time I personally witnessed a timing belt go of it's own accord was on a K car. On a non-interference who cares, but on these, you're screwed. Better safe than sorry.
Sometimes I wish I'd kept that van - it was before the rear seat 'stow and go' business, the back seats unlatched from the floor and came all the way out giving you a mini cargo van which was quite useful. It was clean with no rust, however the engine developed a bad piston slap, was burning lots-o oil, then when the head gasket went out I decided to let it go. Those early caravans were known 'death traps' so in that respect it's probably better that I got rid of it.
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
I have seen many belts go for reason of only age. I will say that I haven't seen this in the last 12 years so many belts are better now.
my friend has a t5 in 2006 xc90 and he replaced the belt at 180k and the belt looked like new. He was a little pissed I had bugged him to do it.
- Has thanked: 311 times
- Been thanked: 817 times
But hopefully he also replcaed the timing path parts? Since that's the whole point of the service.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Did a full timing service today on my S70 because I was always suspicious of the PO's quality of work. Turned out he did a total hack job and didn't even replace the tensioner pulley which had a bad bearing and was going out.
Cheaping out on the timing service doesn't just screw you, it also screws the next owner, especially if you tell them you "did the full timing service".
Knows enough to be dangerous
I’m convinced , with some data to back in the timing belt MTBF thread, the later timing belt system mtbf is > 150k miles. Of course, running to the the mtbf is the ~50% failure rate, so that’s a poor strategy , but if the components are 100k old, no reason to panic and go DEFCON 1 that weekend.
You can drive a new to you Volvo home and dothe job on your time. Keep you karmic bucket full too.
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
I'm a bit confused here.
Continental timing belts are only $12... That's pretty cheap to me. Well when I say cheap I mean affordable... Is there a lower cost option? A pack of rubber bands tied together???
- Has thanked: 316 times
- Been thanked: 531 times
Yeah, it's really not worth cheaping out. When you buy the full kit, what could you be saving by going with Dayco or Gates over Continental, $50 max? It's just not worth it to save that $50 in the long run.callahanoffroad wrote: 06 May 2019, 05:20 I'm a bit confused here.
To clarify, the belts aren't the problem with those kits. I'm more concerned about potentially poor quality pulleys/bearings.
- 5271 Views
Last post by jimmy57
- 23 Replies
- 17186 Views
Last post by jonesg
- 20 Replies
- 17434 Views
Last post by Hurtfeelings
- 14 Replies
- 4799 Views
- 909 Views
Last post by PS78
