IPD sale Volvo Parts
Did you know? 🤔
Oil leak after routin oil change
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
Mattvh
Year and Model: 2001 s 80
Has thanked: 1 time
Been thanked: 0
United States of America
Mattvh
Post by Mattvh » Wed May 08, 2019 6:06 pm
Hi I have a 2001 s 80 non turbo. After I changed oil, it has been leaking from the passenger side. I can not locate the leak. The only variable I can think of [first time working on Volvo] is that I did add oil to the oil filter about half way. Anyway, it did not leak oil before the oil change, but not is it leaking oil. Any help would be great thank you.
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 1 time
Been thanked: 30 times
tardcart
Re: Oil leak after routin oil change
Post by tardcart » Wed May 08, 2019 6:48 pm
coincidence. though a light viscosity or synthetic will turn 1 drip into 3.
These users thanked the author tardcart for the post:
Mattvh
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 11 times
DeadEric
Post by DeadEric » Wed May 08, 2019 7:07 pm
Did you replace the o ring on the filter cap, get it in the right spot and get it tight?
Mattvh
Has thanked: 1 time
Been thanked: 0
Mattvh
Post by Mattvh » Thu May 09, 2019 6:09 am
Thank you for responding. I did replace o ring. I thought I put o ring is same location, but on Saturday I will check. Again thank you for your hel!
Mattvh
Has thanked: 1 time
Been thanked: 0
Mattvh
Post by Mattvh » Wed May 15, 2019 10:00 am
Update on oil leak. Saturday I investigated the oil leak. On the engine block, above the drive axle mounting location on the passenger side, is a “hex” style bolt. The oil as best I can tell was dripping oil from there. The thing is, when I went to tighten it, i don’t believe I moved the bolt, not even a millimeter! But I must have just the littlest bit, because that did stop the leak. Thanks for all the help
