Looks like Chrysler/Dodge has been using Behr-Hella for some of their OE radiators since the mid-90s through at least 2012-2013 that use this style twist-lock petcock. The design appears specific to Behr radiators. However, the Chrysler replacement part, though close, I can tell from pictures has slightly altered dimensions from what is inyour pictures. If the used aftermarket radiator you got hold of was manufactured more recently (probably - especially if it looked really clean/like new), maybe this (fits newer Behr rads?) petcock is what might fit it.
It's probably worth investigating. Two potential part numbers:
Chrysler 4644269
Doorman 61134 (Help! line of products for Chrysler/Dodge OE radiators).
Behr Hella 1/4 twist style radiator drain plug, replacement Not availlable
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
marcus
- Year and Model: S60 2002
- Has thanked: 12 times
The petcock on the picture is from nissens. I was thinking that maybe it will work. Its new. But does mate the rad.
Saab was manufactured by GM. Will they have the same?
The oryginal one looks some what like the Saab. The wing to handle it were square not like on the picture trapezoid.
I will have the Chrysler one today afternoon.
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
[quote=mar
Do you have original radiator? What kind of engine do you have?
The petcook om the picture does not fit. Is just for reference only.
I was informed at Volvo dealer that Behr Hella was suplier to Volvo.
[/quote]
Its a 96 turbo. it had 135k miles when I got it so could be original radiator.
[/quote]
- Has thanked: 1614 times
- Been thanked: 4078 times
Changed title for search
I would put a SS screw into a rubber stopper, bung it into the hole, and wire a safety from the screw up the radiator
After a couple of search interations, I haven’t found a source for these yet.
No , I think thats a pipe thread style,
The 1/4 twist style are a coarse thread, bayonet style.
My Nissens replacement (third rad in car) has this 1/4 twist style.
- mrbrian200
The picture of the hole in his radiator clearly isn't threaded. But I'm starting to wonder if that picture is of the exact radiator in his car.
You wouldn't be willing to confirm whether that picture showing a radiator in post #1 is your currently installed radiator, your old radiator, or a picture of some other random radiator 'for reference' (that may or may not match what is on your car/need) ?
marcus
The Chrysler part number petcock is too big. The diameter is about 18mm. For my rad i need about 15mm.mrbrian200 wrote: 09 May 2019, 23:20 Looks like Chrysler/Dodge has been using Behr-Hella for some of their OE radiators since the mid-90s through at least 2012-2013 that use this style twist-lock petcock. The design appears specific to Behr radiators. However, the Chrysler replacement part, though close, I can tell from pictures has slightly altered dimensions from what is inyour pictures. If the used aftermarket radiator you got hold of was manufactured more recently (probably - especially if it looked really clean/like new), maybe this (fits newer Behr rads?) petcock is what might fit it.
Chrysler 4644269
- 1167 Views
Last post by 850oldschool
- 3371 Views
Last post by darrylrobert
- 19 Replies
- 5651 Views
Last post by RickHaleParker
- 9 Replies
- 3956 Views
Last post by E Showell
- 757 Views
Last post by precopster
