Not sure why but my windows always fog up in my 98 V70R.
It's almost like it fogs up worse when I have the climate controls turned on.
Any idea why?
I cleaned the inside and outside of the windows too, still does it.
Thanks,
Justin
Really foggy windows
TheOtherside
- Year and Model: 1998 V70R
- Has thanked: 55 times
- Been thanked: 5 times
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
TheOtherside
Also, I smell coolant in the cabin now that om paying attention to it...
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
TheOtherside
Thank you so much! I'll start looking!crlande wrote: 10 May 2019, 16:56 Either the HVAC drain is clogged or the heater core is leaking which sometimes tends to leave a film on window.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
When you wipe the windows down is it a bit white and potentially a bit milky? If so, that is most definitely your heater core.
Good luck!
Good luck!
2023 Lexus RZ450e -66k
TheOtherside
I'll look! What should I wipe them with? Windex? Should I wipe them down with the climate control on or off?wizechatmgr wrote: 10 May 2019, 17:16 When you wipe the windows down is it a bit white and potentially a bit milky? If so, that is most definitely your heater core.
Good luck!
Thank you guys for the help!!!
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- RickHaleParker
- Been thanked: 980 times
A clean dark colored cloth with nothing on it. You are trying to find out what the color of the stuff stuck on the windshield is and nothing more.
Active
Past
Past
TheOtherside
I'll look! Thank you kindly!tardcart wrote: 10 May 2019, 17:27 best to order online a Bahr or volvo heater core. dont source local or allow your mechanic to decide.
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
it is an easy DIY job. just be sure to have two large bags under the heater core if you pull it pr you will have quite some water running where it is hard to dry out.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 1299 Views
Last post by E Showell
- 13 Replies
- 2666 Views
Last post by stephansvolvo
- 1110 Views
Last post by mrbrian200
- 24 Replies
- 8106 Views
Last post by FlorenceTravis
- 1686 Views
Last post by precopster
