I noticed in the video that your intake timing mark stops at the same spot both times. It goes around once freely then stops on the second go around.
I don't know what that means exactly but I think it's a clue. Points to mechanical in my mind, hopefully someone more knowable can chime in.
2000 C70 2.4 T (B5244T) has spark + fuel
- Been thanked: 4068 times
Go through and systematically check that the coils are in the right place. I can see that the loom has been reworked - it might be the colour coding has been changed so you will have to sort that out somehow
That kick and backfire is indicative of spark being there but on the wrong cylinder.
You do have an ignition problem of some kind, or timing of valves.
Kerpre
- Year and Model: 2000 c70
Thanks for your reply mate
Cam and crank sensors are good (giving signal) and no codes
Compression on each cyl is at least 155psi so I don’t think it’s washed the rings.
I’ll list off a few things I’ve checked. If you can thi k of anything g else that would be great. Also how do I check the tps? I though this vehicle has an electronic throttle body.
So,
Compression is all atleast 155psi on all cyl
Fuel at the rail is 48psi
Injectors are cycling (have removed rail and cranked over)
Timing appears to be spot on.
No codes for anything(using obd2 memo scanner)
Good strong spark
Cam and crank sensors have been pulled and bench tester and checked out.
I just can’t think of anything else it may be.
Thanks for your help
Kerry
So,
Good strong spark
Kerry
- RickHaleParker
- Been thanked: 979 times
Make sure the Coil Pack Loom is connected in the correct order.
There is one striped wire that is a different color for each cylinder.
Per the Electrical Wiring Diagram (EWD).
Cylinder 1 Yellow-Black.
Cylinder 2 Orange-Black
Cylinder 3 Blue-Black
Cylinder 4 Green-Black
Cylinder 5 Yellow-Red.
Active
Past
Past
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
What RHP said.
Also, can you hook that thing to VIDA and see if you get any feedback there? Only other thing I can think of would be immobilized issues, but that should set a code.
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
Kerpre
Hey guys thanks for the posts.
Ignition cables are all matching up apart from cyl 4
I have black with grey stripe.
I’ve decided I’m going to re-time her and see how we go from there
- RickHaleParker
Had a '97 S90 that flat refused to start unless the camshaft position sensor was disconnected. Turned out the PO had gotten the blocking cup on the end of the camshaft installed 180° off. Corrected that and it fired right up with the camshaft position sensor connected.
My S40 would not start after a timing belt service. Disconnected the camshaft position sensor then with some extended cranking it started.
Worth a shot to disconnect your camshaft position sensor and give it a try.
Active
Past
Past
Kerpre
Alrighty fellas!! After 6 months of struggle, the c70 lives! Runs a little rough but she is running ! Thank you Rick for posting the ignition wiring, my 1 &2 cylinders were around the wrong way and marked as Sony the prev owner
I should of bloody checked
Thank you again guys
Sommerfeldt
Nice! All’s well that ends well!
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
- RickHaleParker
Let me guess ..... had trouble telling the Yellow from the Orange.
There is a reason electrical guys insist on good lighting.
Active
Past
Past
- 1410 Views
Last post by jantt
- 1440 Views
Last post by shiloh51933
- 12 Replies
- 2133 Views
- 457 Views
Last post by chris11211
- 3060 Views
Last post by Roger_850T
