How to remove wood trim on centter console? (And tighten it up)
wrybread
Year and Model: 1998 S70 GLT
Has thanked: 15 times
Been thanked: 15 times
Post by wrybread »
Ahem, there's no such thing as a 12v led... A 12v led is just an led that someone else already wired up... Splitting hairs I know.
Carlo the Nautic Blue 1998 S70 GLT
Previously Diego the 2000 S70, now has a blown head gasket and is awaiting the coroner
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
wrybread wrote: 11 May 2019, 01:22 Ahem, there's no such thing as a 12v led... A 12v led is just an led that someone else already wired up... Splitting hairs I know.
A true 12V LED has a chip resistor included in the same package as the LED.
This is a true 12V green LED. It has the current limiting resistor built in.
The chip resistor is selected for 12V operation.
No additional resistor needed. That is what qualifies it as a 12V LED.
Active
Past
wrybread
Post by wrybread »
I know what you're saying of course, but there's still no such thing as a 12 volt led. LEDs vary with their color from 2.1 volts to 3.4 volts. That green led has a forward voltage of around 2.5 volts depending on it's shade of green. Adding the resistor is just the process if wiring it up (whether it's embedded in the LED's diffuser at a factory or soldered to it). I can also buy LEDs with resistors already added to the wire and neatly heat shrinked, but I wouldn't call those "true 12v LEDs" either.
RickHaleParker
It is a 12V device for the same reason the radio is a 12V device.
Active
Past
Been thanked: 4065 times
You power a 12 V DC LED with 6 2VDc batteries wired in series, of course .
RickHaleParker
abscate wrote: 12 May 2019, 04:10 You power a 12 V DC LED with 6 2VDc batteries wired in series, of course .
No No ... you use 8 AA, AAA, C, or D cells in series. :wink:
Active
Past
