Hey guys,
My HVAC has started behaving badly... After running fine for a while the fan will slow down, then go up 100%, possibly blow some hot air, and then drop back down to normal, all in a span of about 5 seconds. Any thoughts on what could be causing this?
"surging" HVAC fan and random heat...
- clarkerussell
- Has thanked: 20 times
- Been thanked: 4 times
- Has thanked: 1504 times
- Been thanked: 3817 times
Two things to explore
If the cabin temp sensors get clogged ECC will be erratic
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
[Sold] '97 S70 T5
[Sold] '97 S70 T5
THis is what happens when you post after being up for 36 hours post red eye flight..
If the fan motor is giving up the ghost and dying, it will get erratic, too. Sometimes you will notice it changing as you brake and accelerate the car
- clarkerussell
Thanks goodness, I thought you had stroked out our something...
The fan is a noticeable item, but I'm equally confused by the surge in heat when it's been set to cool. I'm going to have to test the cabin temp sensor...
Try vacuuming it out first. The sensor has a tiny fan that pulls in cabin air to feedback to the ECC control unit. It often clogs up with pet hair and other detritus.
markone
- Year and Model: 2007 V70
- Has thanked: 21 times
- Been thanked: 14 times
Where is the sensor located?
2006 V70 NA/manual trans, 165k
2007 V70, NA/manual trans, 143k miles
2023 BMW X1, 29k miles
2018 Jeep Grand Cherokee LTD, 91k miles
2007 Malibu Response LXi, Ebony/white, 340 hp, 395 hours
1997 850 Sedan NA, manual trans, sold at 330k miles
1998 V70, NA/manual trans, sold at 365k miles
In a 1997, up near the grab handles on each side of the car near your ears
In 1998-1999 , it transitioned to a dash position , next to the heated third rear seat button to right of steering wheel,
- clarkerussell
Following up on this... 4 years later...
I am still having the issue after cleaning the interior temp sensor. And the "surging" of the fan is not like the fan motor failing, but more like the HVAC controls changing it to high speed like it was trying to defrost or something.
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
was about to say 2019 cant be 4 years ago but...clarkerussell wrote: ↑11 Sep 2023, 13:52Following up on this... 4 years later...
I once had HVAC controls in a manual climate control system begin to switch between AC, defrost, and other positions as a result of cold solder joints over 20 years. I reflowed the main joints to the control connector which rectified the issue.
2008 S60 2.5T Auto (Sold)
