Replace crank seal and oil pump seal
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Post by loveMy850 »
Hi guys, can you tell me what I need to move out of the way to replace oil pump seal, and crank seal on my 1994 Volvo 850 wagon I don't have to drop the engine do I? I've seen videos where you don't have to. I need some insight on this. Thanks guys ......
Has thanked: 1611 times
Been thanked: 4071 times
Timing belt comes off and then the harmonic balancer , or crank pulley.
Engine stays in
loveMy850
Post by loveMy850 »
Thank you so much Abscate, Story to tell, I had the seal replaced once before, and I was told a BiG Whopper.. Oh well live and learn. Thank You...........................!
It’s a harsh world out there, but MVS has your back.
loveMy850
Post by loveMy850 »
Yes it is! Thank you, ( :
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Was it possible the last time they did the rear crank seal? That's a real pain in the backside to get at typically.
2023 Lexus RZ450e -66k
wizechatmgr wrote: 12 May 2019, 00:45 Was it possible the last time they did the rear crank seal? That's a real pain in the backside to get at typically.
Also called the crank seal, and that one does require at least a transmission pull, if not an engine pull.
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
You didnt say why you need this, but almost all seal leaks involve pressure in the crankcase or cheap seals put in for no real reason.
loveMy850
Post by loveMy850 »
No, Thank goodness, it's the front, I've watched a few videos and I think the oil pump seal is directly behind it, correct?, mys well do that to don't you agree? she's had this leak for a few yrs. yeah I know, but it's not a bad bad leak, I'm just ready to get her back up to par. Shes been a lovely car, and shes ready for some: Let's Do This TLC.
loveMy850
Post by loveMy850 »
They didn't do anything but that crank seal, and, oh wait did me for 750 smacks! Ouch! Live and learn.
