'02 V70 XC Shift Cable End/Bushing Topic is solved
joshdecker
Year and Model: 2002 V70XC
Post by joshdecker »
I was pulling the shift cable off the PNP switch today, and found out the bushing on the shift cable end was trashed.
Any idea where I can either get a new shift cable end with the bushing, or a new bushing?
Also, suggestions for how to get out the shift cable adjustment bracket?
Thanks!
Has thanked: 1498 times
Been thanked: 3810 times
Don’t hate me, but when I researched this on my T5 stick shift I found Volvo does not sell the bush8ng, but wants 135 bananas for a whole new shift cable. I did find aftermarket bushings that worked well
I quick peeked on the eEuro site and found P80 bushings , but not P2 bushing, #sad trombone
joshdecker
abscate wrote: 12 May 2019, 04:53 Don’t hate me, but when I researched this on my T5 stick shift I found Volvo does not sell the bush8ng, but wants 135 bananas for a whole new shift cable. I did find aftermarket bushings that worked well
I had reserved myself to the idea of having to call the dealer tomorrow. My concern is I have found the shift cable on some sights, but all have the threaded end without that tip/bushing. Guess I’ll find out tomorrow what the dealer says.
joshdecker
Also, any idea how to get that yellow adjustment clip out of there?
MDK
Year and Model: 2004 S60R
Been thanked: 41 times
Post by MDK »
Junkyard...
joshdecker
Well that was fun! Yup, dealer quoted me $165 for the entire shifting cable, and no guarantee I can get the end off to just replace that.
So, I know they had one at the junk yard that was in decent shape. I cannot seem to figure out how to get the adjustment device out so I can remove the end tip. Any recommendations? I did read this post, but I didn't understand what precopster recommended for getting it out.
viewtopic.php?f=1&t=48488
The yellow part is just a lock and slips out on the closed side - but from what Mike says its likely it crumbles when you do this.
I don't think its that important as I think the threads are in the black piece of the cable? If not, then the yellow is important and don't break it.
joshdecker
Ok, figured it out. If you put a screw driver on both ends and twist them, it will come up. Trying to do one side at a time doesn't work so well.
Josh - I just found a decent bushing from my 1999 manual - on the off chance the AT bushings are the same I can send size?
joshdecker
Thanks, i was actually able to get one from the junk yard locally yesterday. I really appreciate it though!
