Did you know? 🤔
Oil in plugs
TheOtherside
Year and Model: 1998 V70R
Has thanked: 12 times
United States of America
TheOtherside
Oil in plugs
Post by TheOtherside » Mon May 13, 2019 4:05 pm
Is this normal?
I'm hoping it's just from spilling oil?
Hoping......
98 V70R
13 Flex w/EcoBoost
Clemens
Has thanked: 67 times
Been thanked: 35 times
Austria
Clemens
Re: Oil in plugs
Post by Clemens » Mon May 13, 2019 5:21 pm
nope, this is usually pcv blowby. It is either from the vacum tube the you see coming from under the intakte manifold (check if it is loose on top of the motor) or most likely from the oil filler cap gasket getting hard. Have you cleaned your PCV system lately? If not, it might be about time...
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
tardcart
Re: Oil in plugs
Post by tardcart » Mon May 13, 2019 5:32 pm
sometimes you need a new cap besides the cap rubber even with functioning PVC. but thats a weakness of these cars. supposed to be serviced at 60k miles I think. (PVC}
TheOtherside
TheOtherside
Re: Oil in plugs
Post by TheOtherside » Mon May 13, 2019 5:51 pm
Ohk! Thanks guys! I'll check the cap when I get home!
Should I check the hose right next to the cap?
98 V70R
13 Flex w/EcoBoost
tardcart
tardcart
Re: Oil in plugs
Post by tardcart » Mon May 13, 2019 6:10 pm
the head vent hose almost looks like it has a hole drilled in it on the top? It should be oiteker clamped tight and no cracks or holes. its under about 10 pounds of pressure when the turbo is kicked in even with an unclogged PTC. due to blow by and turbo pressure traveling down the vacuum line from the intake manifold to the PTC, The minimum would be check the hose and get a cap rubber and leave the cover off to monitor and put a rubber glove on the oil fill to check for crankcase pressure. search "glove test"
quietlymknnoise67
Year and Model: 2003 C70
Has thanked: 0
Been thanked: 0
quietlymknnoise67
Re: Oil in plugs
Post by quietlymknnoise67 » Mon May 13, 2019 6:20 pm
Get the upgrade cap gasket from IPD
Has thanked: 197 times
Been thanked: 646 times
Trinidad & Tobago
Re: Oil in plugs
Post by abscate » Mon May 13, 2019 6:21 pm
Check both the cap and the PCV hose.
Also, your plug gap seems huge - should be down at about 0.028 " or 0.7mm
TheOtherside
TheOtherside
Re: Oil in plugs
Post by TheOtherside » Mon May 13, 2019 7:19 pm
Thanks guys. So, the cap gasket is on the actual oil fill cap?
98 V70R
13 Flex w/EcoBoost
tardcart
tardcart
Re: Oil in plugs
Post by tardcart » Mon May 13, 2019 7:32 pm
TheOtherside
TheOtherside
Re: Oil in plugs
Post by TheOtherside » Mon May 13, 2019 7:58 pm
Yeah, that hose popped right off. No effort.
Do you guys recommend me waiting to get new plugs until I figure this out, or should I get new ones now?
98 V70R
13 Flex w/EcoBoost
