P80 Ignition switch wiring 9447804 pin outs pin assignments
Rgierer
Year and Model: 1998 V70T5
Post by Rgierer »
No it cranks fine, in fact I have had to recharge the battery after all my efforts with the switch. In fact the wires can start the car just not the switch
Been thanked: 4071 times
Ah. The key has to be in the ignition, even if you arent using it to turn the electrical part. This car (starting in 1999) sniffs for the key and it will start and shut off the engine in 2 seconds if they key isnt found. After that, it will just crank without firing.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
abscate wrote: 13 May 2019, 18:18 Ah. The key has to be in the ignition, even if you arent using it to turn the electrical part. This car (starting in 1999) sniffs for the key and it will start and shut off the engine in 2 seconds if they key isnt found. After that, it will just crank without firing.
OP has a '98. ( With a Throttle Cable! Man, you are just
OBSESSED with these 99-00 P80's... Seek Help! :mrgreen:
Here's the ignition switch straight from the '98 diagrams,
along with the color code chart to help you rat this thing out.
98 P80 Ignition Switch.png (110.85 KiB) Viewed 3720 times
P80 Wiring Color Codes.png (41.06 KiB) Viewed 3720 times
Are you sure you have nine loose leads, not eight?
Wait, they made Volvos before 1999?
Sorry, OP
:oops:
Rgierer
Post by Rgierer »
Here is what I have
50 GN-R
X Y-VO
15A GN-Y
30 R-SB
15L BL-Y
30l R
15. Y- W
S. Y
With this it engages the starter in the on position
If I switch the last 2 to
15. Y
S. Y-W
I have the starter engage at the right time but the ignition isn’t hot to start the car.
I have something inconsistent here. Any thoughts??
50 GN R is in the wrong place. Thats the starter trigger wire
Rgierer
Post by Rgierer »
A couple of things
1 thank you
2 my list above is incorrect
3. I had no green and red, and my yellow and yellow and white were switched.
4 I had blown the #1 fuse
But mostly thank you for your patience
