VIDA 2014D Communication Tool Error
CamZH
Year and Model: '94 850 + '04 S60 R
Post by CamZH »
Hi Guys,
Having some issues with Vida.
I'm not able to select a Communications Tool (DICE)
I've seen its a common problem, but the registry edit suggestions didnt work for me (the entry was already there)
Win 7 Pro (64bit)
IE 11
.net framework 4.5.2 (rolled back from 4.7.2)
Anyone have any ideas ?
cheers,
2004, S60R
1994, 850 T-5 Wagon
CanadianSteel
Year and Model: 2001 V70XC
Been thanked: 4 times
Post by CanadianSteel »
Hey Cam,
I am having the same issue. The communication tool is completely blank with a red X. I have rolled back to framework 4.0 with no luck. If you find anything let us know.
Reference pic
Reference pic
CanadianSteel
Hey Cam,
Just wanted to update you that I have fixed my issue. And for anyone else with this issue here you go for windows 7 64.
Hold windows key + R. Type regedit. Go to Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\.NETFramework
Once there click on the .NETFramework file and you will see 2 values (Default) and InstallRoot. There should be a 3rd value.
Right click .NetFramework than go to new and down to DWord (32bit) and click it. Name the new one "EnableIEHosting" without the quotations. Than right click the item you just renamed and click modify. In the value type "00000001" without quotations. Should be seven 0s and a 1. Click ok.
Congrats. Relaunch the webpage login and you should be able to pick your tool.
CamZH
Post by CamZH »
Thanks for the suggestion,
What's worked for you seems to be a rather common issue.
I've got the registry entry there, but still no dice. (pun intended)
2004, S60R
1994, 850 T-5 Wagon
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Vida DVD:\Install\Utils\EnableIEHostingxxx.reg .
Make sure you run the right one for your operating system.
xxx =x64 is for 64bit operating systems,
xxx =x86 is for 32bit operating systems
Reboot and login.
Active
Past
CamZH
Post by CamZH »
yep, I know this is the normal issue.
But its not my issue.
I'm going to attempt to re-format my machine and start again.
I have a feeling Windows updates have caused something that it doesnt like.
2004, S60R
1994, 850 T-5 Wagon
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Glad I just read this thread. Had an unhappy camper after windows 10 fresh install. Appears to have done the trick!
JoseBQ
Year and Model: 2009 XC60
Post by JoseBQ »
Thanks, I solved my problem thanks to this thread.
fszczesniak
Year and Model: V70 1999
Has thanked: 3 times
Post by fszczesniak »
fixed mine vida with CanadianSteel suggestion. +1 for you
RickHaleParker
My .Net Framework setup. Vida is working.
Active
Past
