These are cheap, but look how they cut those beautiful OEM hoses
- Been thanked: 4068 times
Put these crappy hose clamps on my list to get rid of at next coolant change.
- Has thanked: 316 times
- Been thanked: 531 times
Just order a ton of ABA clamps from eEuroparts. WAY better than those cheapo clamps. Plus they don't strip out and start skipping.
Ive recently found PEX clamps for plumbing are perfect 19mm Oetinger clamps - at about 15 cents a pop in contractor pack. With four house projects underway, I can always find them lying around, too.
If you put three on each hose, and tighten the outer ones, you don't have to either hunt for, nor remove the hose, to install a spare; the culmination of advance planning, personified.
Hey - another semi-colon!
TheOtherside
- Year and Model: 1998 V70R
- Has thanked: 55 times
- Been thanked: 5 times
Wow... 0.041" is a lot! Definitely time for new plugs!
TheOtherside
Yeah... lol. I was going to change them eventually, but someone here pointed out the gap. Changed them the next day. Lol
98 V70R
13 Flex w/EcoBoost
13 Flex w/EcoBoost
Solved the bad smelling brakes after full braking application....by replacing the smoked rotors and pads.
1999 T5
1999 T5
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
(Mostly) finished up the XC front end swap on my '97 T5.
Have a few small things to address, but it's all in place and the car is mobile again.
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
That's an awesome looking R.bmdubya1198 wrote: 12 May 2019, 19:51 Installed the jewels today after soldering in new pig tails for the bulbs yesterday (some idiot cut them before I got to the lights). Looks much better now!
Yesterday I also installed a used ETM with a 2006 date code, so it’s not as old as what I was running. Hopefully this will last me a while until I pull the trigger on a Xemodex. Then tomorrow I’m going to try to finally find this boost leak. It’s loud as hell while driving, I can’t believe I still haven’t been able to find it yet.
I didn't know there was a date code on the ETM. My 99' has a yellow label one, I have to check the date on that.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Thanks!850 LPT wrote: 17 May 2019, 06:30 That's an awesome looking R.
Yeah, the yellow label ETMs are the newer ones that I believe are supposed to be improved. If you look at the second line down on the left just above the Magneti Marelli logo, it'll have two numbers and a "W", then two more numbers. That's the year and week. So for example, 99W46 would be 46th week of 1999.
This article shows it: https://blog.fcpeuro.com/3-reasons-a-19 ... -great-buy
