Did you know? 🤔
Valvebody, Does it matter?
2001 - 2007 XC-70
goldmandan
Year and Model: 1999 S 70, 2000 V70
Has thanked: 0
Sweden
goldmandan
Post by goldmandan » Wed May 15, 2019 5:52 pm
I will be looking into replacing the valve body on my wife's 2001 S60 with 90k miles on it in a few weeks. The fluid was drain/filled a while ago by a shop (no idea if they used the correct fluid as it was done before we bought it). Right now it drives ok but once engine is warmed up and you come to a stop and quickly want to make a right turn, seems you lose a gear (as if it's a standard shift car) and then bumps and you get the gear back. I am suspecting the valve body but at this mileage??? Should I run a trans tune in it , drain the fluid that's in it and refill with Toyota IV/Mobil 3309?
Now, the real question, If I had to replace the valve body, I heard 2001-2002 are special transmissions, different than the other years because of a difference in the neutral or something. Can I get a valve body from any Aisin AW55 trans? Or any valvebody from 2001-2007 S60/V70?
Dan
MacNoob
Year and Model: 2007 XC70
Has thanked: 2 times
Canada
MacNoob
Re: Valvebody, Does it matter????
Post by MacNoob » Wed May 15, 2019 7:13 pm
Could be valve body. Could be as simple as incorrect fluid level. There is a specific process for checking fluid level. It has to be done with transmission HOT after a long drive. Engine running, parked on a level spot. Move shifter through all gears. Then remove dipstick and check fluid level.
01/02 shifted to neutral when stopped. This was quickly disabled with a software upgrade early in most cars' life. New valve bodies are available on ebay for other versions of the AW55, they require some modification to work in the Volvo. This will require some research on your part to track down various forum threads discussing this.
Also research B4 Servo cover.
A place to start:
https://www.matthewsvolvosite.com/2001- ... embly.html
viewtopic.php?f=9&t=62140
https://www.volvoxc.com/0/resources/how ... -Notes.pdf
vtl
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 29 times
United States of America
vtl
Post by vtl » Wed May 15, 2019 9:35 pm
Sounds like you still have a stop-neutral feature. Disable it: TCM reload at dealer or about $100 if you own a DiCE and buy a 3 day VIDA subscription.
If you really need a valve body, most likely it is an early version, with no stamped letter or letter "A". https://www.sonnax.com/tech_resources/2 ... tification
2005 XC70 250k
2016 XC60 40k
goldmandan
Has thanked: 0
Sweden
goldmandan
Post by goldmandan » Thu May 16, 2019 7:10 am
OK, THIS GIVES ME SOMEWHERE TO START! THANKS GUYS!! WILL REPORT BACK WHAT I FIND OUT. SORRY FOR THE CAPS, MY KEYBOARD IS MESSED UP!
marcus
Year and Model: S60 2002
Has thanked: 10 times
Been thanked: 0
marcus
Post by marcus » Sat May 18, 2019 2:47 pm
Most common problem is that the solenoid get cloged. Oil is degradating by time, even if the car has low milage. So it is worth to check first if the solenoid are ok.
