ATF JWS3309 Service Method ?
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Mine started slipping slightly after about 4 oz into original 1161640 ATF, which I'm suspecting for having extra modifiers compared to other T-IV like ATFs.
Glazing is easy to fix: replace ATF, let HFM wear out. It is naturally wears out along with the friction material, and is replenished from ATF.
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
MDK...so after reading you all's post about the lube gaurd additive. And one man was saying even a 10 oz bottle may cause it to slip over time. Add to the fact that I just did a full flush on both my 2002 V-70 non turbo and my 2004 R car. I've decided to put 1/2 a bottle in one..half a bottle in the other. .. rolling on.
Mikele82
- Year and Model: XC70 04 + C30 T5 08
- Has thanked: 30 times
- Been thanked: 3 times
I'm at 180k miles (2004 xc70). gears shift well on plain and downhill, but uphills feel like a slip here and there, more than usual.EngineeringBloke wrote: 13 May 2019, 20:21
Note. Some have recommended that for older transmissions, it is gentler to them to just do the drain and fill. But then to repeat the process after a few weeks or months. This dilutes the older fluid to 50%, 25% 12.5% and so on at each change.
My fluid has lost its "pink hue" and now looks a bit toward brown (not dark yet).
Volvo dealer service, Firestone and jiffy lube say not to flush transmission fluid and that they rather not do it (Firestone said they won't at all), saying transmission might fail after a flush.
I guess doing the pan drain/fill wound be best in terms of my car. ("dilute it" every few weeks)
If I dont know what fluid originally was put in, is it ok to mix with the other 3309 brands or should i do Volvo OEM ATF?
Also, seems easier t odo the Flush method.
you think doing that method for just 4-5 quarts would be better ?
https://www.ipdusa.com/files/product/13 ... CTIONS.PDF
Mikele82
Is this Seafoam tune up product compatible with Volvo OEM ATF fluid or other jws3309 fluid?
https://seafoamsales.com/7-things-to-kn ... rans-tune/
Ipd snippet:
"He suggested a Sea Foam transmission additive product that he has used in his own Volvo with good effect. I added it to the tranny and within a few days, the "Transmission Service Urgent" message went away and"
https://www.ipdusa.com/blogs/165/ipd-sh ... ts-dealers
Ipd snippet:
- 1540 Views
Last post by quietlymknnoise67
- 11 Replies
- 11706 Views
Last post by STSCowboy
- 1579 Views
Last post by Turbo_Boss
- 713 Views
Last post by Ozark Lee
- 9 Replies
- 2992 Views
Last post by Pezgoon
