Help identify 2.5T engine plastic mount
Been thanked: 470 times
Post by cn90 »
This is my 2005 XC90 2.5T, this plastic mount crumples...
Does anyone know the PN for this?
Thanks!
Post by cn90 »
I found the answer on reddit!
PN is 8651051, about $28 at dealer for this plastic thingy!
Post by cn90 »
Unless someone convinces me, I see no need to replace this piece.
I removed it from the car and the 3 items (EVAP, Vacuum, and the wire loom) seem to be fine w/o this bracket.
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 12 times
Post by DeadEric »
95% of car part failures are related to heat, vibration or rot. That looks like an anti vibration bracket at a 90° turn.
Adding something it could rub thru that you'll notice before it rubs thru the actual parts is good. Putting the bracket back in and securing the parts with tape or zip ties where it's broken is better. Replacing the bracket is best.
My car and that bend I'd try to cobble something with the broken part and check it at oil changes. Pretty sure (without looking them up) the 3 things that run thru that bracket are all more than $28.
amblerman
Year and Model: 1999 s70
Been thanked: 70 times
Post by amblerman »
what is actually broken about it?
Post by cn90 »
The round part where the bolt goes in stays with the engine.
If you look carefully at the 2nd photo above, you will see the broken part.
