Recharging A/C... fan not coming on
Been thanked: 4068 times
Go to a two stage 3 cfm electric vacuum pump, no air driven crap
It will pull To 28 inches vacuum in seconds. When you have it all together correctly , it will hold overnight.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
abscate wrote: 19 May 2019, 19:59 Go to a two stage 3 cfm electric vacuum pump, no air driven crap
Good deal, I'll pick up one of those when I'm ready to fix this!
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
jimmy57 wrote: 19 May 2019, 10:48 The fan runs due to sensed high side pressure. It will need to have something close to 1/2 of the refrigerant charge before the pressure would be high enough for ECM to run the fan.
When you are adding refrigerant with engine running or doing any a/c diagnosis you run engine at 1200 RPM or a little more. This is standard a/c service practice. All vent temps and all pressures you will find in any reference will assume you have system at a speed where compressor is at a speed where it works at its rated displacement. The other standard diagnostic settings are windows closed, fan at 3/4 speed, and recirculated air setting.
Evacuating the system isn't going to make any noticeable difference in charging speed. It is to get the moisture out and to get the air out that can dilute the refrigerant a wee bit. The refrigerant needs to go in slow when it has to run to charge. Too much liquid going in washes away the oil from compressor and you can get too much liquid on top of pistons to be compressible and cause compressor failure.
Tons of good info jimmy57, thank you.
Our 1997 850 with close to 178,000 miles will see its 24th summer. But AC cooling has been intermittent for past 4-5 summers. Last year, an AC recharge attempt lasted a 3 mile drive.
This weekend, I checked the compressor clutch gap, it was 0.63mm. So after placing 3 zip ties, the clutch gap closes to 0.25-0.30mm all around. Ran the engine/AC but the clutch did not engage, therefore, suspecting low refrigerant charge.
For next step, unless you feel EVACUATING procedure is premature, the 1200-1500 RPM method for filling appears logical for diagnosing.
You say "That car has a pressure switch on the low side line behind the engine that is used for compressor clutch control." Is this applicable to 1997 850? ITEM #45 in diagram below.
Yes, your 1997 has the switch in series with the clutch voltage commanded by the ECC control unit. If you jump that switch with wire with AC commanded on, it will engage the compressor clutch.
The most common point of failure is the evap core inside the climate unit - dash has to come out to fix.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
abscate wrote: 20 May 2019, 14:33 Yes, your 1997 has the switch in series with the clutch voltage commanded by the ECC control unit. If you jump that switch with wire with AC commanded on, it will engage the compressor clutch.
Expect a full two days to do that core swap unless you want to kill yourself.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Just a heads up. I got several cans of R134A from Walmart that will screw on both of my hoses but won't discharge. Even with a leak, he should of been able to feel the can get lighter.
Active
Past
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 53 times
Post by callahanoffroad »
RickHaleParker wrote: 20 May 2019, 15:27 Just a heads up. I got several cans of R134A from Walmart that will screw on both of my hoses but won't discharge. Even with a leak, he should of been able to feel the can get lighter.
This happened to me with some pag oil from Walmart last summer.
bmdubya1198
That's interesting. The can I'm using is from Walmart. Maybe I should try my other can I got at Autozone.
bmdubya1198
xHeart wrote: 20 May 2019, 11:56 Tons of good info jimmy57, thank you.
I believe the low pressure side switch is #21 on that diagram.
#21 is the high pressure switch. It has three electrical connects. Be careful with that puppy, and look up the price on FCP if you want to know why,
You can tell the #45 is the low pressure side since it comes after the evaporator, after expansion. It is also on the same line as #31, the fill port.
