Heh everyone.
Just purchased a new Mann oil filter online and it comes with the rubber o-ring but no crush washer.
After crawling under the car yesterday and shining a shop light on the plug, it seems it might be an aluminum crush washer.
Is this correct? Not sure what size to ask for.
Crush washer?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
They are aluminum and the size is 18x24x1.5mm.
https://www.fcpeuro.com/products/volvo- ... v50-v70-xc
Go to any volvo webstore, insert your vehicle, and you will find most parts needed.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
In a pinch a spark plug seal unscrewed from spark plug will work. If your threads are boogered up and you need a longer drain plug you can use a spark plug too. Spark plug screwed in as drain plug is best if you have an audience.
Mr. Detail
Thank you "XC70 Rider" for that info and thanks to "jimmy57" for a bit of humor on my Monday morning.
- Been thanked: 504 times
Keep the orientation the same. The side faces the bolt has a slight indentation.
My crush washer has been re-used at least 20 times, zero leak. Tighten it, then add a bit, do not over-tighten it.
Do you recommend Cu, Pt, or Ir for a spark drain plug?jimmy57 wrote: 20 May 2019, 07:48 In a pinch a spark plug seal unscrewed from spark plug will work. If your threads are boogered up and you need a longer drain plug you can use a spark plug too. Spark plug screwed in as drain plug is best if you have an audience.
If I use Ir, will the oil last 100k miles?
Should I use Volvo or Bougicord for the spark plug drain wire?
Do I have to gap them? Should the gap tool be oiled?
I just can't help myself from this one....
jimmy57
If you use synthetic oil you MUST use at least double platinum. For Amsoil users iridium is a must.
(I am serious, most oxygen sensors are 18mm threads and the spark plugs in white engines are that size too. The new DI engines use 14mm threads to reduce real estate for room for the injector but they still use 18mm drain plug)
Oh and another thing. I bought a metric dimension aluminum seal washer assortment from Amazon for around $10. It is loaded with usable seals for drain plug, trans drain plug, diff and angle gear, and washers for drain plugs on other things besides Volvo. Most of the sizes have 20 each.
Mr. Detail
On a serious note, I found a bunch of old copper crush washers from my Saab days. Wouldn't they make a better seal than aluminum?
XC70Rider
If they're the correct size you can copper or aluminum washers on the oil and AT sumps.Mr. Detail wrote: 21 May 2019, 08:49 On a serious note, I found a bunch of old copper crush washers from my Saab days. Wouldn't they make a better seal than aluminum?
The differential gears and Haldex take the same size washer but requiring less torque on those fill plugs I used copper washers on them.
- 15 Replies
- 8643 Views
Last post by volvolugnut
- 2838 Views
Last post by dm635
- 642 Views
Last post by jonesg
- 390 Views
Last post by cn90
- 36 Replies
- 24649 Views
Last post by StickyPocket
