Help with dashboard removal, 1999 S70
800artfreed
Year and Model: 98 S70T5; 99 S70GLt
Been thanked: 26 times
Post by 800artfreed »
Hi Everyone
I need some help with the dashboard removal. This is a 1999 S70-glt. I have removed EVERYTHING necessary to get the dash out of the car. Seems as if there is an additional screw or bolt over the glove box area that is holding it in place. I have the dash pad removed. I have the 4 long bolts out from the firewall. The passenger airbag is removed. The two screws at the bottom of the "tails" of the dash near the door frames, left and right are out. Both kick panels are out. Radio, A/C-Heater control is out of the console. Hand brake/gear shift console is out. Two lower screws at the foot of the main dash console are out. Of course the steering wheel, airbag, 2 stalk switches are out. The driver's side is lose, as it is suppose to be, but not the passenger side. When pull on the dash it just feels like there is something holding it. It does move a little bit from the windshield but not like the driver's side. Is there some additional fastener behind the glove box / air bag area? Thanks.
Reason: improved title
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Where does it feel like it's hanging up? High up in the dash area or lower.
You said ""over the glove box area" but I wanted clarification on that.
The dash pad is out. I know there are 3-4 10 mm bolts you have to take off under the glove box area but I think those have to come out for the dash pad to come out so it can't be those.
-A
800artfreed
In a fit of frustration I just pulled harder and the dash broke free. All of the tabs to the firewall are cracked and in multiple pieces. The top trim piece near the windshield/alarm light has running cracks as well. I will try the ABS cement and put some together but am leaning towards going to the PnP and grab another 1999 dashboard. Of course it could be as bad or worse but the existing one is very noisy with noticeable looseness between the windshield and dash trim.
Thanks.
VolvoVoyeur
1998 S70-T5 200K+
1998 V70-T5 200k+
1999 S70-GLT 80k+
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 52 times
Post by callahanoffroad »
I am debating whether or not to tackle this job right now on my '95. If I had a second car I think I'd do it. But I'm having difficulty justifying two days of down time so that the smacking dash sound is less annoying. Incidently I found a piece of a dash mount on the floor yesterday. Not really a confidence building sign.
Has thanked: 1505 times
Been thanked: 3818 times
15 minutes with JB weld and butyl tape on the dash to window connecting space and its quiet forever.
Has thanked: 292 times
Been thanked: 765 times
abscate wrote: 20 May 2019, 17:14 15 minutes with JB weld and butyl tape on the dash to window connecting space and its quiet forever.
where does the JB Weld go?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
amblerman
Post by amblerman »
In case you haven't seen my write up on my dash repair, here it is:
viewtopic.php?f=1&t=81991
It's worked for me and my dash is still quite after a year.
-A
Ocelot
Year and Model: 1998, S70
Has thanked: 61 times
Been thanked: 17 times
Post by Ocelot »
Check this out. Helped me out a lot when I removed the old VDO Dayton GPS system.
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Ocelot wrote: 21 May 2019, 06:47 Check this out. Helped me out a lot when I removed the old VDO Dayton GPS system. ...
Probably a good video most of them from IPD are, but that's just the dash pad. Pulling the dash pad is the first about 8% of the dashboard removal process.
'06 S60 R, 197k
Ocelot
Post by Ocelot »
Oh, my bad! Thought it may help you.
Recent car
