Exterior trim color back
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
Hey black Bart..MDK here. Yep...so the Penatrol works pretty good... but if the tailgate or bumper is real gray it'll make it darker but, not all the way. I saw a guy use a heat gun,, that got it back to the original color but, got too close and the paint started to bubble up. Uh..as far as the new tires... yeah date code is good ..no shimmy..no wobble and tracks straight. Got the antifreeze done .. I'm glad I did the old stuff looked like tap water coming out... not good. Drove it around and everything looks good...fan cycled.. I'll check it tonight after it burbs and top it off.
- RickHaleParker
- Been thanked: 979 times
Forever Black is a plastic dye. It will last as long as the original finish.MDK wrote: 22 May 2019, 11:39 Penatrol works pretty good... but if the tailgate or bumper is real gray it'll make it darker but, not all the way. I saw a guy use a heat gun,, that got it back to the original color but, got too close and the paint started to bubble up.
Make sure you do not get Forever Black on anything you do not want permanently stained. Like your paint job.
[youtube][/youtube]
Active
Past
Past
- MDK
Hey all... so I checked out RHP' s video. I've seen that guy before on YouTube. But considering the 2 part process cleaner/ dye . I'll stick with car wash and the Penatrol. you caneven do the wiper blade bolt covers and the lower valance under the wiper blades...I think it's like 12$ a quart... which I paid 2$ if someone on the forum tries it then you'll see...cures up in about an hour...beads water like wax...
- RickHaleParker
Robert Spinner of Albuquerque, NM. MVS member RSPI.
It is your time you decide how to use it. Yes it is a two step process and you would want to take the pieces off the car to prevent staining the paint but, you do not need to keep redoing it. It is a restoration not a cosmetic makeover like the stuff you are using.
Active
Past
Past
- MDK
MDK here... presuming this a G rated audience, I'd like to respond to RHP's comment of "cosmetic". Penatrol is not cosmetic, hence the phrase, To penatrate. Proof is in the pudding, so this must be butterscotch. So, i did my wipers and lower valance. Last for years, beads water like wax. It's a little tacky so wear gloves ( I didn't) if you get some on the glass or paint wipe off BEFORE it sets up. Any exterior plastic or rubber. I do not sell or have any shares in the Flood Co. I just go with what works. I'm a non attorney spokesperson. Hahaha..... rolling on
- RickHaleParker
Penatrol, the wetting agent for applying herbicides.MDK wrote: 28 May 2019, 16:42 MDK here... presuming this a G rated audience, I'd like to respond to RHP's comment of "cosmetic". Penatrol is not cosmetic
Penatrol is Paraffinic Oil, which most of you know as Mineral oil or Baby oil.
Active
Past
Past
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
-RickHaleParker wrote: 28 May 2019, 22:14Penatrol, the wetting agent for applying herbicides.MDK wrote: 28 May 2019, 16:42 MDK here... presuming this a G rated audience, I'd like to respond to RHP's comment of "cosmetic". Penatrol is not cosmetic
I saw a video recently of someone using Transmission fluid to rejuvenate bare black plastic on the exterior. Couldn't find it but found this other video of mixing equal parts Mineral and Baby Oil? Why mix the 2 in equal parts if they are the same?
I purchased a gallon of 303 (30320) UV Protectant last year and tried it for the first time on the 03 S80 T6 about two weeks ago and it brought back the black immediately but has no shine or sheen. Will wash the car again soon and see how it held up as I didn't clean the plastic with alcohol or special cleaners beforehand.
- Has thanked: 311 times
- Been thanked: 817 times
Not sure if you realize MoVolvos but: Rick is making fun of a spelling error, his comment is irrelevant. MDK is talking about Penetrol, which is not baby oil.MoVolvos wrote: 28 May 2019, 23:44-RickHaleParker wrote: 28 May 2019, 22:14Penatrol, the wetting agent for applying herbicides.MDK wrote: 28 May 2019, 16:42 MDK here... presuming this a G rated audience, I'd like to respond to RHP's comment of "cosmetic". Penatrol is not cosmetic
- 1098 Views
Last post by Volvo S80
- 836 Views
Last post by bmdubya1198
- 3003 Views
Last post by pmondrian2025
- 882 Views
Last post by packetfire
- 1072 Views
Last post by SuperHerman
