Wheel bearing Hub puller
- Has thanked: 1503 times
- Been thanked: 3817 times
Re: Wheel bearing Hub puller
You don’t pull the front wheel bearing off the hub.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
I replaced similar one (Optima?) in the donor chassis I got recently. It barely did 20-30k miles. Buy Volvo or FAG.Mr. Detail wrote: ↑23 May 2019, 06:28 Thank you all. " oragex" I planned to replace the whole hub with bearing included. About $75 new. With that said do I still need the puller?
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
people are getting mixed up, the original question is if he needs a puller to get the hub assembly out of the knuckle. Often they are rusted in place and have to be beaten out (discard) or use a slide hammer. Use a three jaw to push back the axel if rusted In the hub as suggested.
do not keep screwing the puller against the axel to remove the hub as the transmission or axle will be damaged possibly. from large side load not designed to resist.
- Been thanked: 471 times
I don't get mixed up.
Once the 4 bolts holding the bearing are removed, it is just a matter of some hammering, it will come out.
- 2185 Views
Last post by [email protected]
- 1774 Views
Last post by sleddriver
