At least he took time to solder that crap together and not just use crimp connectorsWhatAmIDoing wrote: 23 May 2019, 20:38 Another fun filled day. Boost gauge started behaving weird. Then car cut out along with lights, boost gauge, and dash. Fuses were blown for the immobilizer, dash, light switch, and headlights. Popped out the light switch and was greeted by perhaps the worst wiring job I have ever seen. Like seriously... this is horrendous. Who takes the time to break out the soldering iron and then does this, and doesn't even bother to tape up the exposed wires? Spent a good part of my day fixing this hack job, insulating it properly, and uninstalling the boost gauge. Makes me wonder what other wiring projects the PO attempted.
1999 S70 "AWD" Rescue Thread
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
BMW 540i 2002
S70 Base 2000
Its impressive when your soldering is so bad that vampire clips look good.
Im saving that picture for my electricans resume....
- Has thanked: 316 times
- Been thanked: 531 times
abscate wrote: 24 May 2019, 10:44 Its impressive when your soldering is so bad that vampire clips look good.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I just don't get how you can do that bad of a job. If I was going to do it wrong, I would have just shaved a little insulation off of the wires, wrapped the harness wires around it, then tapped everything up and call it good. This is just over doing it sooo wrong.
After fixing that mess, I now no longer have the bulb out indicator on every time I turn on the headlights. Also bench tested the boost gauge, and miraculously it survived. Might wire it back in sometime in the future.
Knows enough to be dangerous
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
WhatAmIDoing wrote: 04 May 2019, 12:13 Put down some white paper towels to catch leaks. Heater core installed is a Behr. Will monitor.
When I did my latest core, I didn't drain the system prior to removing the core. I put a heavy-duty contractor black bag under the core and collected it all on the driver's side. Didn't spill a drop. Found green coolant in the car. Topped of with G05, for now. Under time pressure to bet the car back on the road prior to some surgery.
All U.S. market models.
All running and on the road.
- WhatAmIDoing
That's exactly what I plan on doing. System is full of Volvo blue-green coolant.Eddystone wrote: 26 May 2019, 11:05WhatAmIDoing wrote: 04 May 2019, 12:13 Put down some white paper towels to catch leaks. Heater core installed is a Behr. Will monitor.
- WhatAmIDoing
Project is moving forward. Got the car washed and waxed. New wiper blades. Did a littler interior cleaning. Ordered sparkplugs, fuel filter, air filter, and cabin air filter to complete the tune up. Also picked up some decent used license plate brackets. Painted them black for rust prevention. Removed the old bracket, cleaned up the mess behind it, and installed the new bracket with new hardware. Now she's ready to get plates tomorrow.
Still have the peculiar issue with fast turn signals when the headlights are on. Need to investigate further, but not sure what to look at.
My white paper towels have detected no coolant drips under the heater core. I ran the heat full blast for a short drive with the windows down. Now there's a brief smell of coolant for a minute when turning on the heat but it rapidly dissipates. Wondering if the PO did replace the heater core but didn't bother to clean up the coolant mess inside the plastic housing before reinstalling. Will monitor coolant level in the bottle for the time being.
Trans leak seems very minor. Haven't noticed a change in the level on the dipstick. Fluid still smells new.
That headlight switch is probably toast, there was a recall on that, too, but probably expired now.
Losing voltage on the light circuit will fubar the turn signals, Shirley.
jjss70
- Year and Model: 99 s70 Turbo AWD
- Has thanked: 7 times
To: What am I doing, or Abscate. Could you please take a picture of what you guys know as the TCV ? I have a 99 S70 Turbo AWD that I don't think has a correct turbo control valve or an accurate vacuum hose diagram or an actual FPR at the exhaust manifold on passenger side at firewall as per the only vac. hose diagram from PNP and thanks inadvance. jjss70.
You probably have the 1998 vacuum hose diagram under the hood like mine.
Volvo Fail
I did a complete sketch of the 99 system in my thread on cold idle troubleshooting last year including sizes. Will find and link.
Volvo Fail
- 10 Replies
- 1341 Views
- 40 Replies
- 4760 Views
Last post by E Showell
- 11 Replies
- 19465 Views
Last post by volvolugnut
- 14 Replies
- 2353 Views
- 68 Replies
- 9504 Views
Last post by manovlov
