2006 V70R head gasket leak -- weighing options
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
So if I go the used mill route, what kind of compression test numbers should I be looking for in the used unit?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 4069 times
Should be in VIDA , isn’t the R engine unique in stroke/bore.....and therefore compression, too?
Found this in All-data, your science trained lawyer can do the MPa to psi conversion
- E Showell
Don't even know what units MPa refers to.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
So roughly 160-190 psi.
'95 855 auto (sold)
'95 855 auto (sold)
Pascal’s are SI units of pressure.
MPa is 10E6 Pascals
1 atmosphere is 101,000 Pa, so 1MPa is about 10 atmospheres pressure.
I get the same numbers as you in psi
MPa is 10E6 Pascals
- E Showell
Anybody know whether I can stick that used mill, w/accessories on it, into the back of a P2 XC70?
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 311 times
- Been thanked: 817 times
Glad you're going the swap engine route, much easier and safer (less prone to failure) than doing the head work. Don't know about the transport question.
- RickHaleParker
- Been thanked: 979 times
Megapascal (MPa) = 1 Million Pasacls = 10 Bars.
1 Pasacl = One Newton per square metre.
1 Megapascal = 1 million Newtons per square metre.
1 Pascal = 0.00014503773801 pound/square inch (PSI)
1 Megapascal = 145.03773801 pound/square inch (PSI)
Active
Past
Past
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Would it be catastrophic or too dangerous to just try tightening the head bolts in sequence a quarter of a turn to see if the leak goes away or is minimized a great deal? Years ago I did that with 3 cars but each were leaking oil rather than coolant. 87 Acura Integra, friend's 88? Mitsubishi Galant & 88 Camry. Budget, time and mileage prohibited doing anything else but that. Did work for all 3 cars.
Neither but that is not going to fix a blown gasket. Once they blow they get damaged , so squeezing won’t fix them
It’s also wasted work to get to the head bolts, too.
- 18 Replies
- 6038 Views
- 509 Views
Last post by erikv11
- 4779 Views
Last post by V70r carbon
- 796 Views
- 981 Views
Last post by turtlehead
