2006 V70R head gasket leak -- weighing options
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
MoVolvos wrote: 29 May 2019, 00:58 -
Would it be catastrophic or too dangerous to just try tightening the head bolts in sequence a quarter of a turn to see if the leak goes away or is minimized a great deal?
You run the risk of over stretching the head bolts and snapping them in two. You don't want to do that on a Volvo White block. Typically when a head bolt snaps on a White block it does so about 2 inches below the top of the deck. Time consuming and a PITA to get out.
Active
Past
Has thanked: 311 times
Been thanked: 817 times
Would it be catastrophic or too dangerous to just try tightening the head bolts in sequence a quarter of a turn to see if the leak goes away or is minimized a great deal? Years ago I did that with 3 cars but each were leaking oil rather than coolant. 87 Acura Integra, friend's 88? Mitsubishi Galant & 88 Camry. Budget, time and mileage prohibited doing anything else but that. Did work for all 3 cars.
I don't think I would do it but wouldn't hurt to try, especially if you go in with a torque wrench. If you somehow manage to snap a head bolt, the engine is going to the scrap yard anyway ...
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
The one (unsuccessful) head R&R I tried previously involved a helper snapping off a head bolt in the block. We got it out with much gnashing of teeth and engineering language and a lot of time, but the engine leaked oil from the head thereafter and ultimately went to Valhalla. Thus my inclination to just swap the engine.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
E Showell wrote: 29 May 2019, 09:48 ... Thus my inclination to just swap the engine.
+10,000
On the flip side I've had successful head R&R's and engine swaps, and I'd still much rather swap the engine than open up the old one. Be sure to refresh the timing path and accessible seals, maybe even the ones inside the oil pan, before you drop it in.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Thanks for the all answers to my question. I guess it's safe to try it only if the engine was not worth doing the head gasket. Could possibly buy sometime while a suitable replacement engine was sourced if it did work.
Been thanked: 4065 times
I’m on the camp
Get head off, not too much work, and if bolts snap, swap engine
Evaluate head at shop, no more labor, can still bail
Big decision fork..if head isn’t questionable, new head vs engine swap?
New gasket, machine shop work not too bad
E Showell
Post by E Showell »
Machine shop work, gasket, anaerobic sealant, valve stem seals, new head bolts and proper head removal tools start to approach cost of used engine for uncertain result. Not sure I'm with you on that one.
'95 855 auto (sold)
E Showell
Post by E Showell »
Anybody know whether a B5254T3 would be compatible? Thanks.
'95 855 auto (sold)
RickHaleParker
E Showell wrote: 30 May 2019, 20:10 Anybody know whether a B5254T3 would be compatible? Thanks.
Swap a B5254T3 in lieu of a B254T4?
Short block yes, same Bore and Stroke.
Long block, the B254T4 has a lower compression ratio 8.5:1 vs 9.0:1 for the B5254T3 to accommodate the Borg-Warner K24 turbocharger used on the B254T4.
A long block, B254T3 It would run but, there a elevated risk of blowing a head or over stressing a rod and you will need to use high octane fuel, no more cheap fuel for you.
Should scream louder than it ever did before.
Active
Past
E Showell
Post by E Showell »
Yeah --- Looking for reliability. I guess the hunt for the B5254T4 continues, although, truth to tell, I don't push the car hard.
'95 855 auto (sold)
