2006 V70R head gasket leak -- weighing options
Has thanked: 311 times
Been thanked: 817 times
E Showell wrote: 30 May 2019, 20:10 Anybody know whether a B5254T3 would be compatible? Thanks.
The B5254T4 has different internals too: forged crank, different connecting rods and rod bearings. Would probably work fine but risks internal damage long term.
You can also consider a B5244T5, i.e. from an S60 T5, like 05-09. Or V70 but I think a narrower set of years. It's 9.0 but shipped with the same K24 turbo. But in your shoes I would probably try to be patient for a B5254T4, short of digging into it and wading through a lot of reading about what swaps people do with R vehicles.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
V-Band Style K24 Specifications:
Volvo Part Number: 8603298 (old 8602805, 8677954, 30713137)
Manufacturer Part Number: 5324-970-7400
Turbo Model: K24.2474DXBAA6.GAAXM, K24-7400
Vehicle Fitment: 2004 - 2005 Volvo S60R/V70R (B5254T4 Engine)
Coupler Style K24 Specifications:
Volvo Part Number: 8603692 (old 30757114, 30650636)
Manufacturer Part Number: 5324-970-7401
Turbo Model: K24.2474DXBAA6.GAAXM, K24-7401
Vehicle Fitment: 2006 - 2007 Volvo S60R/V70R (B5254T4 Engine), 2005-2009 Volvo S60 T5 (B5244T5 engine)
Active
Past
RickHaleParker
erikv11 wrote: 31 May 2019, 08:22
You can also consider a B5244T5 B5254T5, i.e. from an S60 T5, like 05-09. Or V70 but I think a narrower set of years. It's 9.0 but shipped with the same K24 turbo.
The B5254T4 software running a B5254T5, same risk as going to a B5254T3. However if he going to take the risk he would be better off with a B5254T5 rather then a B5254T3.
A B5254T6, B5254T8, B5254T10 or B5254T11 should work as well as the B5254T5 and he is more likely to come upon a low mileage engine.
Active
Past
Rick I'm not following, why the strike-through here? I actually do mean the S60 T5 engine from the mid-2000's, which is the B5244T5. Not too hard to find, and people have actually used it for this swap, with R software. Smaller displacement and all. The B5254T5 has a bad history of cracked cylinder liners, so several other engines have actually been tested already with the R tune.
RickHaleParker wrote: 31 May 2019, 14:10
Whatever source you are copy-pasting from says the same thing. i.e. "2005-2009 Volvo S60 T5 (B5244T5 engine)."
RickHaleParker wrote: 31 May 2019, 13:27
RickHaleParker
erikv11 wrote: 31 May 2019, 17:49 Rick I'm not following, why the strike-through here?
Had my mind on the Rs overlooked the T5.
The B5244T5 has a bore of 81mm. The B5254T5 is 83mm. The B5244T5 cylinder liners are 1mm thicker and less prone to cracking, better reliability.
The B5244T5 might be a better choice for him. Probably sacrificing some of the 296 hp and 295 ft-lbs torque of the B5254T4 and perhaps pissing off some R purest but, it is his car and his pocket book, he can do what he pleases.
What the hell, R stands for Refined, not Racing or Rally. If one considers Reliability a Refinement they would be keeping with the spirit of the R badge.
Active
Past
Been thanked: 4069 times
He Really needs to get this back on the Road before SWMBO puts out a contRact on him and he ends up I the fields somewhere in NJ. Leave the gun. take the pastRies
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I can get a T3 mill with 62K miles on it . . . Yep, 62K miles -- still, I will most likely go with a T4 with 160K miles. Local seller, free delivery, 1 year parts AND LABOR warranty (up to $75/hr).
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
I’ll pencil you in Evan
Abscate sees $75/hr and starts planning to exploit that labor warranty ...
Warranty is only as good as the attorney enforcing it...we’ve got a good one for that....
